Hot Water Boiler Pressure - HVAC - DIY Chatroom Home Improvement Forum
Old 12-29-2008, 09:03 AM   #1
hot water boiler pressure
Okay it is me again. I have emptied the expansion tank, all was good for a short while. When the furnace is finished heating up and turns off, the pressure continues to increase to 30 psi, then of course the relief valve releases water, approx. 1/2 pail full.
Any suggestions, or should I call for service?
raineywillow is offline   Reply With Quote
Old 12-29-2008, 09:21 AM   #2
If it's not the tank than it is the more than likely the pressure reducing valve (prv) is not regulating properly. This is located where the domestic water connects to the boiler for filling. There should be a gate valve or ball valve near the prv so you can turn the water off to verify the prv malfunction.
SKIP4661 is offline   Reply With Quote
Old 12-29-2008, 09:28 AM   #3
What is your water temp set up for? Are tripping valve on temp or press.
What is boiler press staying at?
hvaclover is offline   Reply With Quote
No hot water pressure at kitchen faucet tracker883 Plumbing 2 12-30-2008 05:10 AM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 10:24 AM
Water pressure issues - in one part of the house stream41 Plumbing 4 11-11-2008 07:43 PM
Help - Very Low Hot Water Pressure Renoguy Plumbing 4 04-16-2008 12:27 PM
Pressure Fluctuation with well water beertestr Plumbing 5 10-03-2007 09:18 AM
