Hot Water Boiler Furnace-shut Off/on - HVAC - DIY Chatroom Home Improvement Forum
Old 12-25-2004, 02:01 PM   #1
Hot Water boiler furnace-shut off/on
Posting 2nd message. Found problem of low flame on one burner. Piece of teflon tape caught in orifice of burner log. Main question: Furnace burners run for about 15 minutes and then shut off. Rest for about 5 minutes and then furnace is back on for 15 minutes. This cycle continues all day. Result is low how water temp in baseboard heating units in house. Perhaps has something to do with an overtemp switch? Is this shutting down furnace. Thermostat is still calling for heat but house only get to 62 F. Question: Why is it sutting down?
Nashman
Nashman is offline   Reply With Quote
Old 01-14-2005, 11:54 AM   #2
Does your thermostat have an anticipator setting? If so, check it. It may be set too low. Increase your boiler temp.
Chandler is offline   Reply With Quote
Water in my furnace? Jonboat HVAC 9 07-24-2014 10:04 AM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Hot water boiler furnace-insufficient heat Nashman HVAC 2 11-06-2011 06:15 PM
Bleeding air - Hot Water Boiler Dragon HVAC 10 10-30-2006 08:13 AM
Water level in boiler system Barefoot Brian HVAC 3 10-19-2006 01:11 PM
