Hot Water Boiler Furnace-insufficient Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 12-20-2004, 07:34 PM   #1
Hot water boiler furnace-insufficient heat
Temp dropped to zero F in Michigan. Hot water furnace only gets house to 60F in house. Installed new circulating water pump today, no help. Installed a new gas regulator last march. Have lots of yellow tips on top of blue flame. Have five cast iron burners. The burner closest to the gas valve has very low flame and is the last to light, lags by 10 - 15 seconds. Has 1/4 inch high flame the other burners ares 3 to 4 inches high. Unit is peerless boiler and about 30 years old. In previous Winters at Zero it seemed to be able to get to 70F in the house. Water temp in boilers is 160 F and pressure gage says 19 psi
Can any one comment or suggest adjustments. Would or does the new gas valve need adjustments?
Thanks Nashman
Nashman is offline   Reply With Quote
Old 01-14-2005, 11:51 AM   #2
I am assuming that this is a Gas boiler. If so check your burner tubes for buildup, clean the orifices in all tubes, check your gas pressure,increase your boiler temp to 180 degrees and turn down your pressure to 12psi.
Chandler is offline   Reply With Quote
Old 11-06-2011, 06:15 PM   #3
Check for drafty doors and windows increase insulation in attic seal drafts at sill plate put plastic over windows , check for aire in rads.
saves is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Bleeding air - Hot Water Boiler Dragon HVAC 10 10-30-2006 08:13 AM
Water level in boiler system Barefoot Brian HVAC 3 10-19-2006 01:11 PM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 08:57 PM
