Hot Water Boiler - HVAC - DIY Chatroom Home Improvement Forum
Old 11-25-2009, 03:58 PM   #1
Hot water boiler
Quick question
If you have a boiler that was dormant for awhile and the water to the house was shut off but is now on is it alright to start the boiler?Will there be any air in the system
skippy
Skippymartinez is offline   Reply With Quote
Old 11-25-2009, 04:28 PM   #2
The boiler has just been of the summer.
Skippy
Old 11-25-2009, 04:29 PM   #3
off for the summer srry.
Old 11-25-2009, 04:35 PM   #4
An old Tradesmen
Rewards Points: 7,332
If it was drained. It will need filled. And the air purged/bled from the system.
If it wasn't drained. Should be fine.
Old 11-25-2009, 06:03 PM   #5
I do not have to worry about any steam build up because of the water being of and maybe the boiler not being filled? automatically by the pressure reducing valve
Old 11-25-2009, 06:25 PM   #6
An old Tradesmen
Was it drained?
You should look to see if the guage is indicating that there is water in it.
Most auto water feed is not designed to leave water travel in both directions.
Plus, unless the pipes were disconnected, the water should not have been able to drain out anywhere. Other then if the boiler has a leak.
Check the boiler guage to see if it shows pressure.
If you have rads. Go to the highest one, and open its bleeder, and if you get water. the system is full.
Old 11-25-2009, 08:10 PM   #7
ok thanks you have been a big help
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Hot water boiler furnace-insufficient heat Nashman HVAC 2 11-06-2011 06:15 PM
My boiler doesnt have any water in it. Leoskee HVAC 13 09-21-2009 12:34 PM
hot water boiler heating raineywillow HVAC 3 12-26-2008 07:51 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-13-2007 11:16 PM
