Hot Water Baseboards Noisy! - HVAC - DIY Chatroom Home Improvement Forum
Old 01-09-2010, 02:14 PM   #1
Just call me Andrew
Rewards Points: 1,020
Hot water baseboards noisy!
Is there any trick to reducing the amout of constant "pinging" noises emitted from hot water baseboards? Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 01-09-2010, 02:42 PM   #2
JohnH1's Avatar
A couple of things. Look to see how the elements are mounted. Make suer they are just setting on the brackets to allow for movement. Also you may be operating the water higher than needed if you are only controlling water temp by the boiler high limit. For example at -10 deg outside you may need 180deg water but as the temp gets warmer you dont need as hot of water to maintain the same comfort. But on a call for heat the boiler just runs up to full temp. You can eather controll manually by turning down the high limit or install a outdoor reset control. The less the water temp the less the expantion and contraction. Just a idea.
John
JohnH1 is offline   Reply With Quote
Old 01-09-2010, 03:49 PM   #3
Just call me Andrew
Thanks, John. Is there a way to "bleed" the baseboards of air? Is this necessary? I know it is on older radiators.
Is there a proper formula to figure out what water temperature to use based on the outside temperature? Would this increase or decrease boiler efficiency?
Andrew
Old 01-09-2010, 06:20 PM   #4
JohnH1's Avatar
Unless you have no heat or here a lot of air gurgling in the lines you shuold not need to bleed the lines.
Without figuring a heat load and knowing the amount of radiation you have we can guesstimate with
standard copper tube baseboard that at 60deg outside to use about 110deg water.
Then at the other end of a plot line at -10deg outside the water should be about 190deg.
draw a plot line and find the coresponding water temp at the assoiated outdoor temp. the lower the temp the better but if you go to low you will not have enough heat.
Outdoor temp
-10
0
10
20
30
40
50
60
70
120 130 140 150 160 170 180 190 200 Water temp
Old 01-10-2010, 02:41 PM   #5
Just call me Andrew
John, what did you mean by this exactly? Thanks.
Andrew
Old 01-10-2010, 06:46 PM   #6
JohnH1's Avatar
I have seen a few times the elements zip-tied to the brackets.
Old 01-10-2010, 06:49 PM   #7
Just call me Andrew
Ah, OK. by elements...is that the pipe running through the baseboard, or the fins?
Andrew
Old 01-10-2010, 06:59 PM   #8
JohnH1's Avatar
The element is a copper pipe with aluminum fins attached/pressed to the copper. The fins will be open on the top and bottom allowing air to flow through with a chimney effect.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
