Hot Water Baseboard, Upstairs Works, Downstairs Not - HVAC - DIY Chatroom Home Improvement Forum
Old 11-07-2012, 06:18 PM   #1
Hot water baseboard, upstairs works, downstairs not
We have hot water w/ baseboard splitlevel. It's a 1962 home with hard water. Furnace, thermostat and pump is working. The upstairs baseboards are very warm but no heat to the downstairs. The pipes to the upstairs is hot but not the pipe after the split that goes to the main level.
If it's an air plug, might it work itself out over time-there is some knocking when the water starts circulating.
If it's a hardwater plug, could it work itself out over time?
It was working last spring.
Would turning up the heat so there is more circulation help or does it create a dangerous situation?
If it does not work itself out, do we need a plumber, furnace person or PSEG?
Any wisdom would be most appreciated.
pleasehelpme? is offline   Reply With Quote
Old 11-07-2012, 06:43 PM   #2
Rewards Points: 616
let the air out first....
carmon is offline   Reply With Quote
Old 11-08-2012, 06:31 AM   #3
Thank you for responding
delete
Tags
air block , hard water , radiator problems
hot water baseboard - what to do laorquidia Kitchen & Bath Remodeling 0 08-14-2012 12:52 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Need advice RE: purging air from baseboard hot water heating system mikenri HVAC 2 01-19-2011 07:17 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Low water pressure upstairs but gauge reads 100psi? rivers72 Plumbing 7 11-15-2008 07:55 PM
