Hot Water Baseboard Return With Pex? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-09-2010, 06:37 PM   #1
Hot Water Baseboard return with Pex?
I have slant/fin 30a baseboards. I cant run a normal return, i need to double it back on itself and have the return inside the baseboard as well. This portion of baseboard is all on slab. Is it possible to run pex (with o2 barrier) inside of the baseboard, or do i need to do this whole thing in copper? Thanks guys
gnosti83 is offline   Reply With Quote
Old 01-09-2010, 06:42 PM   #2
JohnH1's Avatar
I would say if local code permits it the pex is fine. I have used it several times for baseboard.
JohnH1 is offline   Reply With Quote
Old 01-09-2010, 06:44 PM   #3
I know the pex will work, i just didnt know if it was taboo to do since the fins could cut the pex.
Old 01-09-2010, 06:47 PM   #4
JohnH1's Avatar
Pex is very tough. I dont think there any way the fins could damage the pex.
Old 01-09-2010, 07:03 PM   #5
thanks john, i was hoping that would be the case, looking forward to not having to solder more pipe in that cramped space
Old 01-09-2010, 09:12 PM   #6
An old Tradesmen
Rewards Points: 8,170
Run the pex under the element, and fasten it to the brackets, not the element.
Old 01-09-2010, 09:53 PM   #7
Ill take a look to see if this is possible, I would imagine this would be a better scenario as gravity would take the pex away from resting on the fins. However, it looked like there was very little room below to attach to.
Old 01-09-2010, 09:59 PM   #8
An old Tradesmen
And the more room between the pex and the element, the better the heat transfer from the element.
having it rest on top of the element, lowers the heat output of the element. As it restricts the air flow.
Old 01-09-2010, 10:03 PM   #9
Yeah i heard the return line in the baseboard can cut heat output by more then 25%, but my options are limited with the slab
Old 02-01-2010, 04:23 PM   #10
This is what i ended up coming up with, I ran the line on the underside of the baseboard, but i did not like the way it looked as some of the line was visible.
Old 02-01-2010, 05:00 PM   #11
Licensed Master Plumber
Pex expands a lot and I have seen it push the cover off the baseboard. I would use copper till I hit the drop.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 02-01-2010, 07:10 PM   #12
An old Tradesmen
Hope it isn't pulled up tight against the bracket. Or it will rub through.
Old 02-02-2010, 09:45 AM   #13
I think i pulled them pretty tight, i will have to loosen them all up.
Old 02-19-2014, 08:01 PM   #14
Rewards Points: 26
PEX inside slant fin 30
Hi gnosti83, I know it's been over 3 years since this post but I'm hoping to get some info about your inside baseboard return using PEX.
what did you use to make the bend from the fin/tube connection? two 90 elbows or a return bend? if return bend, was it 3/4" 2" center-center? I see return bends on the net but most are 2 1/2" center to center. I'm also curious if you used push fittings such as sharkbites. I too have to add some baseboard over a slab level.
Thanks,
-asb313
asb313 is offline   Reply With Quote
Old 02-19-2014, 09:10 PM   #15
see if this opens for you. This is what i used with one of those pieces vented to release air.
https://plus.google.com/photos/10957...09612780499057
Hot Water Baseboard Heating Issues hivicks HVAC 10 01-04-2010 06:27 PM
baseboard sounds like colorado rapids flowing mynd66 HVAC 10 01-06-2009 08:55 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Air in hot water baseboard - help! heydobbs HVAC 6 12-08-2006 05:08 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
