Old 01-24-2013, 05:12 PM   #1
Hot Water Baseboard Heat - No heat upstairs
Hope someone can help as I'm completely lost....
I got a new gas-boiler last year (Weil McClain cGA). I've got a small Cape-Cod with baseboard heat and the down stairs pipes are hot but when touching the pipes upstairs they are cold to the touch. I've got 2 thermastats, but I believe only 1 zone. (Is this possible)?? I don't understand what is meant by zones.
Both thermastats are on and set to 70. But no heat upstairs. And of course the down stairs is only about 61-62 since it's trying to heat the entire house.
I think I've purged the line, but how do I know if it's done and there is no air?
Will try to post pics tonight of the boiler.
Any help is appreciated
Keith
KJzuck is offline   Reply With Quote
Old 01-24-2013, 06:02 PM   #2
Master General ReEngineer
Bondo's Avatar
Keith
Ayuh,... Are there any air bleeder fittin's in the upstairs loop,..??
What's the pressure, 'n temp at the boiler's gauge,..??
Old 01-24-2013, 07:20 PM   #3
Right now the boiler is set to about 32 psi.
As for the bleeder fittings, how would I know?
Old 01-24-2013, 07:51 PM   #4
how
Most residential boilers will start venting through the pressure relief valve at anything above 30 PSI.
12 to 15 PSI should do your two story home.
A zone is loop of piping that heats an area of your home. It gives you the opportunity to heat different areas to different temps. Two zones should mean two separate thermostats????
No heat upstairs could be an air lock or a faulty zone valve.
Do you have bleed valves on the ends of your rads?
Post pic's of your tridicator, zone valves and the pressure reducing valve.
how is offline   Reply With Quote
Old 01-25-2013, 09:48 AM   #5
Bondo's Avatar
Ayuh,... 32 psi is Way to High,... should be in the 12/ 15 psi range....
Yer auto-feed, 'n/ or the bladder tank ain't doin' their jobs...
As for the Bleeders,... Ya gotta Look...
You'll see a little screw or cap, usually at a corner, or end of a straight run....
No heat upstairs mikelbeck HVAC 4 10-25-2011 09:54 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
hot water baseboard heat cvnative HVAC 1 08-13-2010 07:34 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
