I have very low hot water pressure in the bath. Cold water is ok.
I am told the low hot water pressure is due to the way the baseboard heat system works. Also have heard you can run the water from the boiler into a water heater and then from that to the bathroom and that pressure will increase.
Can you help?
Can you help?
