Hot Water From AC - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-20-2013, 07:17 PM   #16
Originally Posted by beenthere View Post
Its a desuperheater. As known as a heat recovery unit. They can save you a lot on your hot water bill in the summer. They are not a popular as they once were.
They are actually cheaper to use to heat or keep a swimming pool warm the natural gas is. Since all the heat is waste heat that you are paying to get rid of anyway.
Yes sir, you are correct.. More or less.. pulls the heat off the condenser side of your split system
rydan is offline   Reply With Quote
The Following User Says Thank You to rydan For This Useful Post:
Startingover (02-20-2013)
Old 02-20-2013, 09:08 PM   #17
Rewards Points: 2,176
so, are you guys saying that my city water runs thru this "recovery system". (or maybe it did. I don't think this thing works)
Startingover is offline   Reply With Quote
Old 02-20-2013, 10:33 PM   #18
We use condensing units here to heat outdoor swimming pools in summer here ,, they are water cooled condensers instead of air cooled .Works very well ..... gotta run a/c in summer anyways why not put the energy to good use .. A mfg in montreal mfgs a unit that "dehumidfes/heats the pool water /removes humidity and even reheats the air "on indoor pools and they are very cost effective and work very well
hvac dude is offline   Reply With Quote
The Following User Says Thank You to hvac dude For This Useful Post:
Startingover (02-21-2013)
Old 02-21-2013, 04:52 AM   #19
An old Tradesmen
Rewards Points: 7,754
They usually had water lines ran from the water heater to it, and it has/had a circ in it that would run when the A/C ran. If the hot gas temp was above 120░ the circ would run to heat the water in the water heater, provided the water heaters water temp was not above set temp.
The Following User Says Thank You to beenthere For This Useful Post:
Old 02-21-2013, 04:54 AM   #20
An old Tradesmen
Dectron is who I see around here.
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
