Hot Water From AC - HVAC - DIY Chatroom Home Improvement Forum
Old 02-19-2013, 05:15 PM   #1
Rewards Points: 2,218
Hot water from AC
I've never heard of this before.
Next to the 16 yr old condenser there's a metal box, 12" x 14" and about 3 or 4" deep. Its on the house.
I just learned its a 'hot water heater'. Personally I don't grasp why an AC would heat my hot water when I have a hot watertank.
Don't know if it's been working or not. It's not compatible with my new unit. He said a new water heater (for the AC) would be another $900 which I can't afford.
I've been around a lot of contractors and am surprised I never heard of this before. Are these hot water heaters very unusual or popular?
Startingover is offline   Reply With Quote
Old 02-19-2013, 05:35 PM   #2
hi any chance u can shoot us some pics to help us out
hvac dude is offline   Reply With Quote
Old 02-19-2013, 05:44 PM   #3
sure.........hang on.
Old 02-19-2013, 05:46 PM   #4
ok ,,,
Old 02-19-2013, 05:54 PM   #5
Hot water from AC-dscn1542.jpgsure.........hang on.
Old 02-19-2013, 06:33 PM   #6
pics a bit blurry ,,, can the cover be removed for a pick inside ? and any water lines comming to or from the box ?
Old 02-19-2013, 06:38 PM   #7
Thanks.
I'm afraid to open things like this.
Just wondered how common it was for AC units to provide hot water.
Old 02-19-2013, 06:40 PM   #8
not very at all .. just loosen the screws and move cover if its loose you shud be good to go ,, be intresting to see inside
Old 02-19-2013, 07:19 PM   #9
Post
Originally Posted by Startingover View Post
Attachment 65986sure.........hang on.
This is your Heat Recovery Unit..
I'm a HVAC Install mechanic, we don't usually come across these, but when were installing a new system, we always soldier the water lines and discontinue these.
rydan is offline   Reply With Quote
The Following User Says Thank You to rydan For This Useful Post:
Startingover (02-20-2013)
Old 02-19-2013, 07:22 PM   #10
hey rydan are these still mfg ? as the hrv units in canada are complety diff and where is the air handler for the hrv ?
Old 02-19-2013, 08:05 PM   #11
my air handler is in the garage (on the other side of wall in the photo). It's on a shelf about 3' feet high.
Old 02-19-2013, 08:09 PM   #12
The original owners were from N.Y and did a quality job with everything in the house.
I wondered if this was more common up north.
I better call the new AC guy and verify that he will remove this thing.
Old 02-19-2013, 09:59 PM   #13
Missouri Bound's Avatar
The last time I saw one of those it was being used to add heat to a swimming pool.
Do you want it your way or the right way?
The Following User Says Thank You to Missouri Bound For This Useful Post:
Old 02-20-2013, 09:18 AM   #14
Roofmaster
Rewards Points: 2,210
Heating a swimming pool with electric?????? Are they nuts?????
Old 02-20-2013, 05:37 PM   #15
An old Tradesmen
Rewards Points: 8,142
Its a desuperheater. As known as a heat recovery unit. They can save you a lot on your hot water bill in the summer. They are not a popular as they once were.
They are actually cheaper to use to heat or keep a swimming pool warm the natural gas is. Since all the heat is waste heat that you are paying to get rid of anyway.
The Following User Says Thank You to beenthere For This Useful Post:
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
