Hot Water - HVAC - DIY Chatroom Home Improvement Forum
Old 11-27-2012, 09:40 AM   #1
hot water
I think my heater coil is plugged with scale on my oil fired boiler. Is there a way to clean it without removing it.
jonchase is offline   Reply With Quote
Old 11-27-2012, 12:21 PM   #2
Rewards Points: 1,294
What makes you think this? Are you meaning the insides (where the water is) of the exchanger core or the outside surface (fire side) of the core?
danpik is offline   Reply With Quote
Old 11-27-2012, 04:05 PM   #3
An old Tradesmen
Rewards Points: 7,268
If your referring to a tankless coil, they can be cleaned. but not something easy to do the first time you are trying it.
Old 11-27-2012, 05:32 PM   #4
Rewards Points: 1,216
If it's the domestic hot water side I agree with been it's probably not an easy thing to do diy. You need to acid clean it by hooking up hoses and a pump and running that through then neutralize it and disconnect everything. What makes you think it's dirty?.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
