Hot Surface Ignitor Problems - HVAC - DIY Chatroom Home Improvement Forum
Old 01-30-2008, 06:49 PM   #1
Hot surface ignitor problems
Hello all. I have a Rheem early 90's model hot surface ignitor upflow heater. I have a Honeywell hot sufrace ignition control (S8910U). It was damn cold here last night and the heater went out. Easy enough fix it was just the hot surface ignitor. I replaced it and heat was running almost all night to get back up to 72 degrees from the 50 degrees it had dropped to. Came home today and it was cold. Checked and once again Hot surface ignitor was cracked and not lighting flame. Easy enough I changed it out but this time no lighting. It goes through the light up cycle but hot surface ignitor does not light up.
Honeywell Ignition Control was just installed about 2 months ago. On control it says
pulsing - normal operation
1 pulse - ignition lockout
2 pulse - weak flame signal
3 pulse - internal error.
I have seen it when it is working right. It's very bright and pulses very fast. Now the led light pulses about once every second or so leaving me to believe it is in igniton lockout mode. How do I reset this. Or has anyone else had a similar problem and could tell me what I need to do.
hateheater is offline   Reply With Quote
Old 01-30-2008, 07:13 PM   #2
Union HVAC Tech.
Turn off the power and turn it back on after several seconds.
bigMikeB is offline   Reply With Quote
Old 01-30-2008, 07:26 PM   #3
Thanks for the reply. Turned it off for 5 minutes and still nothing. Would the heater running all night have something to do with why it's not working? Have you seen cases such as this? Have Hot surface ignitors been known to be bad from the factory? There are no visible cracks anywhere. I'm just trying to save a few bucks. Thanks.
Rubber playground surface toolbag General DIY Discussions 19 05-16-2013 04:45 PM
Another name for surface wiring/wire-mold? fw2007 Electrical 4 01-09-2008 05:56 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 03:41 PM
Trying to decide between granite or solid surface countertops Proulx06 Remodeling 13 02-01-2007 09:23 AM
new hot surface ignitor, still no luck steve1971 HVAC 3 11-09-2006 06:02 PM
