Old 12-11-2008, 11:35 AM   #1
Hot Surface Ignitor always on
I have a 17 year old American Standard Natural gas furnace. Lately I've noticed that although the unit otherwise is working properly, the HSI constantly glows orange. 24/7. The furnace starts and runs through it's cycles just fine and keeps the house warm. The control box has an LED indicator that flashes the appropriate normal conditions. I'm concerned that the HSI will burn itself out and that it's probably sucking alot of electricity to keep it hot. I'm thinking that I should replace the White-Rodgers control box, but thats spendy if not the problem.
Any one got a suggestion?
Panther is offline   Reply With Quote
Old 12-11-2008, 01:00 PM   #2
I would say that it is the ignition control. I would recommend replacing it. That ignitor produces 1800 degrees. May melt wires etc. if not corrected.
SKIP4661 is offline   Reply With Quote
Old 12-11-2008, 04:11 PM   #3
Thanks for the response. Since posting, I was able to talk to a local tech from the company that installed the furnace. He also confirmed that the control board was the culprit and would require replacement. I'm on it.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
How to take off surface polymeric sand!!! Urgent KUIPORNG Landscaping & Lawn Care 9 08-28-2008 09:17 AM
Surface mounting breaker box Nhrafan Electrical 3 04-09-2008 03:16 PM
Hot surface ignitor problems hateheater HVAC 2 01-30-2008 07:26 PM
Another name for surface wiring/wire-mold? fw2007 Electrical 4 01-09-2008 05:56 PM
