Old 02-24-2006, 12:34 PM   #1
Default hot pilot light supply line
Carrier furnace stopped working - noticed "yellow" pilot light. Removed and cleaned pilot light orfice - now have "blue" pilot light.
Problem: During restart procedure I turned on gas and then switched on power (per instructions on unit), unit has an electronic starter:
First, I heard the gas supply come on to the pilot light before I switched on the power - it then lit the pilot light and the burners iginited - everything seems fine:
Second, I noticed the pilot light supply line became VERY HOT.
Third, when the burners shut down (when room temperature reached setting) I noticed the pilot NEVER SHUTS OFF.
Question: Do I have a bad thermocoupler that is not shutting off the supply of gas to the pilot, or is there another sensor failing?
Any help would be appreciated, Thanks Dennis
dlkk is offline   Reply With Quote
Old 02-24-2006, 07:45 PM   #2
sub-contractor
This isn't making sense to me.
Do you have an electric start, or a standing pilot unit?
Aceinstaller is offline   Reply With Quote
More On This Topic
Types of Stoves
Types of Stoves by Expert Village
So the first thing that you need to do is determine the type of stove you will want. In this situation, we know that it's a gas stove, we have a gas supply, and we're going to...in some cases you may have an electric, in that case you just plug it in... Read More »
Okay, so the next step is to pull out the broiler pan and look into the boiler and in the very back you will see there is the receptacle or the pilot light assembly. You will simply stick a match up to the pilot light and "poof" the pilot light is lit... Read More »
The next thing we are going to do is turn off the gas supply to the stove. There usually is, this is like, I think, a 1/2" or 3/8" gas line, you might want to just replace this. This is a new one. So anyway, you would generally have a gas valve that... Read More »
Hi I'm Betty Ingham on behalf of Expert Village. Now when we take this whole thing and fill it up we're are going to make sure we put our cones in there and we put them where we can look through our peep holes. While it is firing we make sure that we... Read More »
Hi! On behalf of Expert Village my name is Andrea Spano and I'm going to show you how to make Ganache from my new book "Not Just Desserts." Okay. As you can see, the cream is boiling. I'm taking it off the flame. I'm shutting off the heat source... Read More »
Pilot Light Won't Stay Lit etiger1 HVAC 7 10-19-2009 09:09 PM
Turning pilot light off jmcs23 HVAC 5 06-17-2007 10:38 PM
Relocating water supply line from well Mikedks Plumbing 6 09-22-2006 03:41 PM
add an additional register to a supply line b2v HVAC 1 06-20-2006 08:55 PM
pilot light reignition on older williams model Unregistered HVAC 1 02-17-2004 11:26 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
