hot pilot light supply line
Carrier furnace stopped working - noticed "yellow" pilot light. Removed and cleaned pilot light orfice - now have "blue" pilot light.
Problem: During restart procedure I turned on gas and then switched on power (per instructions on unit), unit has an electronic starter: First, I heard the gas supply come on to the pilot light before I switched on the power - it then lit the pilot light and the burners iginited - everything seems fine: Second, I noticed the pilot light supply line became VERY HOT. Third, when the burners shut down (when room temperature reached setting) I noticed the pilot NEVER SHUTS OFF. Question: Do I have a bad thermocoupler that is not shutting off the supply of gas to the pilot, or is there another sensor failing? Any help would be appreciated, Thanks Dennis |
This isn't making sense to me.
Do you have an electric start, or a standing pilot unit? |
| All times are GMT -4. The time now is 07:36 AM. |
