Hot Capacitor? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-27-2010, 04:41 PM   #1
Hot capacitor?
Went to an intermittent no cool call today and came across a capacitor rated for 55/5/440 that tested 54/4.8 so well within specs. It was very hot to the touch which I have never seen before. Do they get hot before swelling up? Replaced it to be safe and the system is working fine now, well fine as it can with a .85 static on a system that lists max external static .5".
Old 07-27-2010, 05:02 PM   #2
An old Tradesmen
Rewards Points: 6,870
Swelling is usually from over heating. The oil boils/expands and bugles the housing.
Old 07-27-2010, 05:15 PM   #3
Thanks beenthere. Did not know that.
Old 07-27-2010, 07:47 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,818
Did you check the voltage and amps draw of the compressor? I always do that when changing caps so I don't get callbacks and da Boss saying why didn't you do that.
Old 07-27-2010, 08:24 PM   #5
Sure did yuri. Fan and compressor amps,voltage,capacitor reading,pressures,SH,SC,return temp and supply temp go on every ticket.
Capacitor Replacement on Central Air unit sn2567 HVAC 6 07-21-2012 02:29 PM
Need help finding specific capacitor! mark2741 HVAC 21 07-25-2010 08:20 PM
run capacitor blew up caught fire in AC unit. saltshaker30 HVAC 2 07-01-2010 09:08 PM
Condenser motor and Capacitor confusion ryanru HVAC 5 06-26-2010 12:25 PM
problems with capacitor motor for pump joeypants Electrical 13 10-13-2009 04:18 PM
