Hot Air Furnace Air Temp? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-08-2012, 08:33 AM   #1
TTW
TTW's Avatar
Hot air furnace air temp?
What is the proper setting for the tstat that cycles the fan on and off.
Oil fired hot air furnace.
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 12-08-2012, 10:16 AM   #2
An old Tradesmen
Rewards Points: 6,142
Auto.
Old 12-08-2012, 11:25 AM   #3
Rewards Points: 610
It's called the limit control on the furnace..old ones are a box with removable cover on front of furnace...normally set around 150 F to start fan and 120 to shut off and have adjustable set point levers...newer furnaces are electronically controlled via integrally mounted thermistor(s) which signal the fan to start and stop. They are small dics that mount to heat exchanger and are not adjustable.
techpappy is offline   Reply With Quote
Old 12-08-2012, 01:37 PM   #4
TTW
TTW's Avatar
Old 12-08-2012, 03:54 PM   #5
An old Tradesmen
100 to 110 off, 140 on. Leave limit at 200.
Thats known as a fan limit control.
Old 12-09-2012, 10:06 AM   #6
TTW
TTW's Avatar
Thanks!
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Heil Furnace problem - is is the undersized vent? mpmusicny HVAC 8 11-20-2012 01:47 PM
Furnace outlet temp Mule98 HVAC 0 11-11-2012 05:21 PM
Lennox furnace shutting down before desired temp reached dringrn HVAC 25 10-12-2012 09:58 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
