Hose Bib Is Leaking - HVAC - DIY Chatroom Home Improvement Forum
Old 12-19-2011, 04:25 PM   #1
sweaty
Rewards Points: 276
Hose Bib is Leaking
My outside hose bibb is leaking. It's probably the original one from 1977. Is it worth repairing? If I replace it, is it easy to do? What is the best hose bibb?
sweaty is offline   Reply With Quote
Old 12-19-2011, 04:35 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Can you take some pics? I've never heard of a hose bibb.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 12-19-2011, 04:47 PM   #3
Household Handyman
Rewards Points: 1,408
Hose bibb---one each:Name:  hose bibb.png
Old 12-19-2011, 04:52 PM   #4
that had better be connected to a geothermal hvac system in the house otherwise I still never have heard of it.
Thanks.
Thanks.
Old 12-19-2011, 05:21 PM   #5
Houston204's Avatar
Rewards Points: 556
A 1977 house will probably have galvinized piping. Turn off the water to the house and replace it with the boiler rated hose bib and some teflon tape from Home Depot or Lowes.
A 1987 house might have copper piping and might involve a propane torch, flux and a 1/2" x 1/2" copper female adaptor as well as the boiler rated hose bib.
The boiler rated bib is worth the extra 99 cents in my opinion.
Houston204 is offline   Reply With Quote
Old 12-19-2011, 06:28 PM   #6
Change the washer.
fitter1 is offline   Reply With Quote
The Following User Says Thank You to fitter1 For This Useful Post:
plummen (12-19-2011)
Old 12-19-2011, 06:33 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What does any of this have to do with HVAC other than a boiler valve was used in place of a sillcock? I must be missing something all around on this one.
XXX
Old 12-19-2011, 07:12 PM   #8
Houston204's Avatar
Rewards Points: 556
It's a valve, we can help. I repair or replace more valves than motors every year (usually proportional chill water valves).
Old 12-19-2011, 10:23 PM   #9
dannyoung85's Avatar
I had the same problem with my hose Bibb. I assume it is a frost proof sillcock since it is on the outside of the house. I replaced the valve packing on mine and it has held ever since.
dannyoung85 is offline   Reply With Quote
running extension from outside garden hose faucet denemante Plumbing 6 05-27-2011 01:18 PM
Drain hose leaking supermex79 Plumbing 4 05-17-2011 08:19 AM
Weathermaker SX Model 58SX080-BC-1 Series 150 leaking hose vel1975 HVAC 1 01-12-2011 09:24 PM
leaking washer hose kenlevesque Plumbing 4 11-28-2010 09:55 PM
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 01:27 AM
