Hookup Visionpro To York Heat Pump System - HVAC - DIY Chatroom Home Improvement Forum
Old 01-27-2011, 11:39 PM   #1
Rewards Points: 12
hookup visionpro to York Heat pump system
I just got a vision pro TH8320 tstat and would like to use it with my York ac/heat pump system. I currently have an old York lever tstat with a slide switch to turn on emergency heat. The wires on my tstat are :
WBGRXOY. The vision pro does not have a b (has o/b), x, and o (has o/b). Can anyone help me with the new wire hookup? Any issues with using this tstat that would make it not worth changing out? It was given to me, would like to use it if its compatible. Thanks for any advice.
mikec35 is offline   Reply With Quote
Old 01-28-2011, 05:46 AM   #2
An old Tradesmen
Rewards Points: 6,112
On older York's they used B as common. The 8320 will have a C/common terminal.
Make sure that your outdoor unit IS a York and not a Rheem/Ruud unit.
Old 01-28-2011, 09:08 AM   #3
Rewards Points: 12
I do have an outside York unit. Does anyone know where I would hook the x and the o on the old York tstat to on the new vision pro? If I understand beenthere I would hook the old b to the c on the visionpro. Thanks
Old 01-29-2011, 07:09 AM   #4
An old Tradesmen
O is O.
X should be aux heat/W2.
Old 05-27-2012, 10:06 AM   #5
Rewards Points: 12
Just now getting around to installing this Tstat. I think I understand how to based on the info given in this post. I am unsure, however if this will work for my emergency heat. How would I tell the tstat to switch over to emergeny heat? My outdoor unit does not have a sensor. Currently on my York Tstat I have a slide switch to turn on the heat strips when I realize the heat pump is not keeping up. Thanks..
Old 05-27-2012, 03:16 PM   #6
An old Tradesmen
The system section of the screen can be set to emergency.
However. You shouldn't turn off the heat pump and use emergency only, that cost more money to heat that way.
If you don't want to install an outdoor temp sensor. Just let the stat decide when to use aux heat based on if the indoor temp is holding or not.
York Heat Pump Wiring Problem floridafrank HVAC 0 01-08-2011 06:51 AM
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 06:51 PM
York Heat Pump nocerpa HVAC 2 08-28-2010 11:27 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 09:34 PM
heat pump cut off set point oldswab HVAC 4 12-02-2009 03:09 PM
