Hooking Up New Thermostat. Just Need Some Clarification - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-03-2011, 07:56 PM   #16
Thanks Master, just for clarity-which screw lug is common?
cruzmisl is offline   Reply With Quote
Old 11-03-2011, 07:57 PM   #17
The "c" terminal
Master of Cold is offline   Reply With Quote
Old 11-03-2011, 07:58 PM   #18
OK, I'll give it a shot and let you know. Thanks for taking the time.
Old 11-03-2011, 08:02 PM   #19
Not a problem..
Where do I send the bill...lol
You still have to hook up that fresh air damper too.
Old 11-03-2011, 08:35 PM   #20
Master, I hooked it up as suggested and the tstat turns on but none of the functions work. I tried to turn the fan on (recirc) and heat on but nothing. Any other suggestions?
Old 11-03-2011, 09:11 PM   #21
Did you go through the installer set up?
Old 11-03-2011, 09:17 PM   #22
I didn't think I needed to since the fan and other functions worked before (but then again it was hooked up wrong). Anything specifically that needs to be changed? I did try to change the system from conventional which was default to auto sense but that didn't make a difference. I did hook up the old tstat just to be sure I didn't burn anything out and it all works ok so thats promising.
Old 11-03-2011, 09:22 PM   #23
Do you have the 3 wires going to the new stat?
Old 11-03-2011, 09:31 PM   #24
Yep, hooked up to 1, 2, 3.
Old 11-03-2011, 09:40 PM   #25
Power it up and wait for 5 minutes. Come back and turn the fan to "on" and see what happens.
Old 11-03-2011, 09:41 PM   #26
OK. Stand by
Old 11-03-2011, 10:06 PM   #27
Sadly I get the same result.
Old 11-03-2011, 10:12 PM   #28
Can you take another pic of the new controller?
Also.. 1,2 and 3 match on the controller?
Old 11-03-2011, 10:18 PM   #29
Yes the 123 all match. I triple checked that. Here's a pic of the controller, I hope its good enough.
Old 11-03-2011, 10:39 PM   #30
What is the model of the new stat?
I am wondering if the stat was damaged during the cool test yesterday. When you hooked the white wire to c, which c did you connect to and from?
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 08:43 AM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 04:32 PM
Thermostat issues rathipon HVAC 4 01-29-2011 11:46 AM
Need help on hooking up a duct fan to thermostat blackhawk16 HVAC 13 01-01-2010 01:48 PM
Hooking up a non-equipped pellet stove to a home thermostat bobbyc HVAC 4 09-25-2009 02:24 PM
