Old 01-08-2013, 11:18 PM   #1
hooking up new thermostat
I am installing a new thermostat and there is no power to the c wire. The c wire seems to act as a ground. I get 28 volts between the c and r wires. Is this normal? I was looking at the transformer on my furnace and there are 2 leads coming out. A fused blue lead that connects to the c terminal and a yellow lead that connects to the r terminal. There is also a wire connected to the c terminal that is screwed into the box like a ground. Is this normal? I was under the impression that the c wire for the thermostat is supposed to be a 24 volt positive wire. Any help is greatly appreciated!!
watter74 is offline   Reply With Quote
Old 01-08-2013, 11:54 PM   #2
R is 24 volt positive.... c is the common....... hope that helps....
carmon is offline   Reply With Quote
Old 01-09-2013, 12:00 AM   #3
If I am getting 28 volts from r to c is that ok?
Old 01-09-2013, 12:03 AM   #4
it sure is.....
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 09:43 AM
hooking up 3 baseboard heaters to one wall thermostat glennbo Electrical 25 02-03-2012 07:42 PM
Hooking up new thermostat. Just need some clarification cruzmisl HVAC 34 11-04-2011 07:05 PM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 05:32 PM
Need help on hooking up a duct fan to thermostat blackhawk16 HVAC 13 01-01-2010 02:48 PM
