-   -   hooking up new thermostat (http://www.diychatroom.com/f17/hooking-up-new-thermostat-168644/)
watter74 01-08-2013 10:18 PM
I am installing a new thermostat and there is no power to the c wire. The c wire seems to act as a ground. I get 28 volts between the c and r wires. Is this normal? I was looking at the transformer on my furnace and there are 2 leads coming out. A fused blue lead that connects to the c terminal and a yellow lead that connects to the r terminal. There is also a wire connected to the c terminal that is screwed into the box like a ground. Is this normal? I was under the impression that the c wire for the thermostat is supposed to be a 24 volt positive wire. Any help is greatly appreciated!!
carmon 01-08-2013 10:54 PM
R is 24 volt positive.... c is the common....... hope that helps....
watter74 01-08-2013 11:00 PM
If I am getting 28 volts from r to c is that ok?
carmon 01-08-2013 11:03 PM
it sure is.....
