Hooking Up A Boiler - HVAC - DIY Chatroom Home Improvement Forum
Old 01-13-2009, 09:45 PM   #1
Rewards Points: 150
hooking up a boiler
i want to replace my boiler with another used one. the one i have now is very old, and the water lines comming out of it are very large (3-4" diameter) steel lines. the one i want to buy had 2" copper lines comming out. what is involved in hooking this up to the large steel lines i have now?
drewhart is offline   Reply With Quote
Old 01-13-2009, 10:20 PM   #2
An old Tradesmen
Rewards Points: 6,590
Big reducing couplings.
Old 01-13-2009, 10:24 PM   #3
biggles's Avatar
you can get reducing adapters that are copper and thread them onto the exsisting 4" ans then pipe into the new boiler with copper from the 2" side of the adapter.....check HD for fittings........exsisting 4" lines are your running steam or HW for heating
Old 01-13-2009, 10:28 PM   #4
JohnH1's Avatar
Thats funny!!! I needed that
JohnH1 is offline   Reply With Quote
Old 01-13-2009, 11:07 PM   #5
Rewards Points: 150
yes its a hot water system.
Old 01-13-2009, 11:13 PM   #6
An old Tradesmen
LOL...
Ok, they reducing bell couplings.
I use cast iron ones.
Using copper female adapters on pipe that large can present small leaks problems when the system comes up to temp.
Guessing his system was gravity at one time.
Old 01-13-2009, 11:27 PM   #7
Rewards Points: 150
so does the copper sweat into the cast iron bell coupling?
Old 01-14-2009, 06:28 AM   #8
An old Tradesmen
You would use a male adapter.
It has a threaded end for screwing into cast/steel fittings, and a sweat end for copper to copper connections.
Circulation pump on boiler uncleneiler Plumbing 4 06-22-2010 10:01 AM
Tankless coil in oil-fired boiler lebeld Plumbing 4 01-18-2009 09:48 AM
Burnham V7 series oild-fired boiler is turning itself off Pickngrin HVAC 6 01-12-2009 09:26 PM
Boiler w. Hydronic Air & Honeywell Aquastat DanA28 HVAC 1 01-08-2009 05:21 PM
Boiler Shut Down SassySue General DIY Discussions 3 01-01-2008 12:49 PM
