Honeywell Zone Valve Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 01-11-2011, 09:59 AM   #1
Honeywell Zone valve problem
I am having issues with 1 of my 2 heating zones. One Zone is not getting heat. The valve will not open even when the manual lever is engaged. This entire system is less then 2 years old. The motor does activate when heat is called and the furnace fires but the valve remains closed. Is this a bad powerhead or do i need to replace the whole valve?
gnosti83 is offline   Reply With Quote
Old 01-11-2011, 10:07 AM   #2
Experienced
Jackofall1's Avatar
Replace the whole valve, keep the head from the faulty valve as a spare.
Old 01-11-2011, 01:01 PM   #3
Did you check the boiler pressure? May be low on water or an air lock in that zone.
SKIP4661 is offline   Reply With Quote
Old 01-12-2011, 08:55 AM   #4
After buying a new zone valve and dismantling the old one i found the problem. Apparently when it was soldered on (like a year ago) excess solder entered into the valve itself. Somehow recently it formed an airtight seal not allowing any water to pass. When i unbolted the valve door and cleaned this out everything now functions properly. I guess i can return my valve now, lucky me. Thanks for all the help guys.
Well check valve problem, well question maxalex Plumbing 7 08-21-2016 02:21 AM
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Zone Valve not working asolarzone HVAC 6 12-12-2010 07:02 AM
Adding Sprinkler Valve to Existing zone tilphan Landscaping & Lawn Care 3 03-29-2009 12:35 PM
Heil problem with gas valve Frank4711 HVAC 1 12-14-2007 10:03 PM
