Honeywell YTH5320R1025 - HVAC - DIY Chatroom Home Improvement Forum
Old 03-18-2012, 11:12 AM   #1
Rewards Points: 150
I have a question. I have a friend who wants to move his current thermostat from the extended living room area into another room. Will a Honeywell YTH5320R1025 kit have everything we need to do this job without running new thermostat wires and make this a wireless setup? I see it has a panel and the thermostat in the kit. We are trying to avoid running new thermostat wire in the process of relocating the thermostat. Here's the kit from Pex supplys
http://www.pexsupply.com/Honeywell-Y...FUKR7QodXxgNHg
thanks
-kilo
kilosos2 is offline   Reply With Quote
Old 03-18-2012, 11:19 AM   #2
GC/Master Plumber/Mech
Rewards Points: 560
It should work for what you want to do.
Keep in mind that after you install this stat you will need to set up the stat for the system you have, which should be detailed in the install instructions.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 03-18-2012, 11:20 AM   #3
An old Tradesmen
Rewards Points: 6,884
Thats a zoning kit. You don't need a zoning kit. You jut nee a wireless kit. But it will work, an has everything you need.
Old 03-18-2012, 11:43 AM   #4
Rewards Points: 150
Yes the part where it describes about the zoning panels made me a bit confused. Thats why I posted the question here. Will a wireless kit cost a bit lesser? This is the cheapest I have found for a wireless setup solution. It seems easy setup. He just has 1 cooling 1 heating. Another thing I want to ask. If I hook up a transformer and use 110 volt and hook up the 24 volt to the common on the thermostat... will that work so we don't need to use batteries. We could probably hid the transformer inside the wall. Although I don't know if he'll let me do that either. LOLL
Old 03-18-2012, 11:47 AM   #5
An old Tradesmen
Thats a pretty cheap rice, and may be a misprint.
Old 03-18-2012, 11:55 AM   #6
Rewards Points: 150
Wait. This kit..... The wireless receiver just has ABCD terminals. Where are all the other terminals like Y1, Y2, W, G,C etc etc? DO I still need a EIM panel?
Old 03-18-2012, 11:59 AM   #7
An old Tradesmen
The A,B,C,D are not used. The regular connections are above them.
The Following User Says Thank You to beenthere For This Useful Post:
kilosos2 (03-18-2012)
Old 03-18-2012, 12:03 PM   #8
Rewards Points: 150
Oh ok cool! Thanks Beenthere
Honeywell TrueSteam wont work! Stewart Daniel General DIY Discussions 18 12-20-2010 07:41 AM
Replacing Honeywell thermostat with another Honeywell flipz HVAC 4 02-06-2010 04:19 PM
Replace Trane Weathertron (Baystat 339) with Honeywell RTH2410 ammiller2 HVAC 0 12-12-2009 09:50 PM
Need a programmable thermostat. LUX or Honeywell. speedster1 HVAC 37 12-06-2009 08:33 AM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 04:43 AM
