Honeywell WiFi Thermostat Install Help - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-25-2013, 09:19 PM   #16
Experienced HVAC Tech
HVAC1000's Avatar
Originally Posted by Bonita2208
Yes, turned power off at the breaker prior to unhooking/hooking everything up, turned it back on after everything was hooked up.
I should have been more specific on the part where it doesn't seem to be working - The fan will come on when we turn it to on, but the compressor/A/C didn't seem to be coming on.
Can u post a picture of your new wiring. Both at the air handler and at the wifi communication board
HVAC1000 is offline   Reply With Quote
Old 07-25-2013, 09:30 PM   #17
Nothing was changed at the Air Handler, only on the wall for the thermostat.
Bonita2208 is offline   Reply With Quote
Old 07-25-2013, 09:35 PM   #18
Rewards Points: 34
Did you go through all of the setup steps and tell the thermostat what type of furnace and AC is connected?
Dan
djlandkpl is online now   Reply With Quote
Old 07-25-2013, 09:48 PM   #19
Yeah, went through all the steps and selected Heat Pump then 1 Stage Cooling because only one Y wire, selected 2 Stage for Heating Stage though because we have a wire in the W2 hole?
I guess the thing that is/was throwing me off is that on the previous thermostat there is that white jumper wire from W to W2...This one we hooked up the O wire to the W-O/B slot and the W to the W2 slot.
Now that I'm typing this all out It appears to maybe be working now - I just tried pushing in all the wires one last time and went back through the setup just to be sure. I'm wondering if maybe I didn't have a wire inserted all the way.
Old 07-25-2013, 09:53 PM   #20
AKA HVACTECHFW
Rewards Points: 1,208
It has a built-in 5 minute delay. Wait at least 5 min after a call for cool
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
HVAC1000 (07-25-2013)
Old 07-12-2015, 08:45 PM   #21
Rewards Points: 4
h8580wf wiring
I am trying to hook this thermostat to my previous wiring. Looks like I can use the B with for the C terminal. What do I do with the Y2, X2, an W1 ? Do I use the jumpers on the others ?. The unit is a trane and only 2 years old.
Thanks !
speedbugy is offline   Reply With Quote
Old 07-13-2015, 06:07 AM   #22
Rewards Points: 46
It's better to start your own thread next time.
Take a picture of the wiring at the indoor units. Is the above picture the old base? What is the new stat?
Cheers!
supers05 is online now   Reply With Quote
Old 07-13-2015, 07:55 AM   #23
Rewards Points: 4
Sorry, thought I did do a new thread. Yes, the pic is of the base that is installed now. The one I want to install is a RTH8580WF.
Thanks !
Replacing a Carrier thermostat with a Honeywell thermostat Fred Lambrerth HVAC 2 07-11-2012 05:02 PM
Question about connecting wires to the RTH2300 (honeywell) thermostat crap_at_diy HVAC 3 11-26-2011 10:50 PM
Thermostat issues rathipon HVAC 4 01-29-2011 11:46 AM
Honeywell thermostat wiring wcb22 HVAC 5 01-10-2011 05:54 AM
Installation of Honeywell Thermostat - cooling function KDW Electrical 0 10-04-2009 09:56 AM
