Honeywell WiFi Thermostat Install Help - HVAC - DIY Chatroom Home Improvement Forum
Old 07-18-2013, 05:21 PM   #1
I26
Question
Honeywell WiFi Thermostat install help
Hello,
I am trying to install a new Honeywell T-Stat, RTH8580WF, to replace my current Honeywell T8011R. The trouble I am running in to is what to do with the W1 and W2 wires. I currently have wires going to terminals G, C, R, W1, W2, O. Honeywell said to connect G to G, C to C, R to R, W1 (tape off), W2 to W2, O to O/B.
Will this bypass the heat pump and run auxiliary heat all the time? I have a heat pump and plenum that provides auxiliary heat when the heat pump cannot keep up.
Thanks for helping.
I26 is offline   Reply With Quote
Old 07-18-2013, 05:40 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
Is w1 currently jumpered to Y on the current stat?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 07-18-2013, 05:47 PM   #3
I26
Yes, W1 and Y are jumpered together on the current t-stat.
Old 07-18-2013, 06:03 PM   #4
AKA HVACTECHFW
The wire from W1 will go to Y1.
IT IS WHAT IT IS
Old 07-18-2013, 06:08 PM   #5
I26
Sorry but I am confused. The new T-Stat has the following terminals: L, E/AUX, K, RC, R, O/B, Y, G, C.
Should it go to Y?
Old 07-18-2013, 06:12 PM   #6
AKA HVACTECHFW
Yes, sorry, it should go to Y
IT IS WHAT IT IS
Old 07-18-2013, 06:14 PM   #7
I26
If this turns out to be wrong will it cause any damage to the system? Not trying to lay blame, just curious is all. Thank you for your help.
Old 07-18-2013, 06:18 PM   #8
AKA HVACTECHFW
It is correct, I'll show you......https://customer.honeywell.com/resou...0s/69-1436.pdf page 3 and no, it wont cause damage because it is right
IT IS WHAT IT IS
Old 07-18-2013, 06:21 PM   #9
I26
Very nice. I will report back once I swap it out. Again, thank you.
Old 07-18-2013, 07:19 PM   #10
I26
I am supposed to set the thermostat system function to 0190 to 0 meaning heat pump changeover valve (for heat pumps only) the 0 means Cooling changeover valve (use this setting if you connected a wire labeled O to O/B.
When trying to set this it skips over the 0190, any ideas?
Old 07-18-2013, 07:25 PM   #11
I26
Nevermind for now, I had to set something else first.
Old 07-18-2013, 08:01 PM   #12
I26
So far it appears that everything is working as planned. Thank you so much for the help.
Old 07-25-2013, 09:00 PM   #13
I'm attempting to also hookup a Honeywell Wifi Thermostat, but I have the RTH9580WF.
Here is our previous thermostat:
We hooked up the new one the following way as I thought it state in the manual:
C wire into C.
R into R.
Y into Y.
G to G.
L to L.
O into the W-O/B
W into W2-Aux/E
It doesn't seem to be working though, just curious if anyone has any input?
We were following Page 18/19 here in the manual that came with our unit, which is here:
http://www.wifithermostat.com/Resour.../69-2809ES.pdf
Bonita2208 is offline   Reply With Quote
Old 07-25-2013, 09:12 PM   #14
Experienced HVAC Tech
HVAC1000's Avatar
C wire into C.
R into R.
Y into Y.
G to G.
L to L.
O into the W-O/B
W into W2-Aux/E
Did u turn off power first?
HVAC1000 is offline   Reply With Quote
Old 07-25-2013, 09:14 PM   #15
Yes, turned power off at the breaker prior to unhooking/hooking everything up, turned it back on after everything was hooked up.
I should have been more specific on the part where it doesn't seem to be working - The fan will come on when we turn it to on, but the compressor/A/C didn't seem to be coming on.
Replacing a Carrier thermostat with a Honeywell thermostat Fred Lambrerth HVAC 2 07-11-2012 05:02 PM
Question about connecting wires to the RTH2300 (honeywell) thermostat crap_at_diy HVAC 3 11-26-2011 10:50 PM
Thermostat issues rathipon HVAC 4 01-29-2011 11:46 AM
Honeywell thermostat wiring wcb22 HVAC 5 01-10-2011 05:54 AM
Installation of Honeywell Thermostat - cooling function KDW Electrical 0 10-04-2009 09:56 AM
