Honeywell Wall Thermstat - HVAC - DIY Chatroom Home Improvement Forum
Old 01-04-2008, 11:51 AM   #1
honeywell wall thermstat
I have ceiling heat with honeywell wall controls. need to replace but don't know how? any ideas. thanks p.s. just the thermal controler, not the whole heating system
fisherman is offline   Reply With Quote
Old 01-04-2008, 12:02 PM   #2
Building and plumbing
USP45's Avatar
Rewards Points: 150
If your replacing just the thermostat I would purchase the same kind, then as each wire comes off, simply install it on the new one right away. Dont try to remove all of them then re install as you may forget where they went. Transfering them one at a time is the safest way IMO.
USP45 is offline   Reply With Quote
Old 01-04-2008, 12:33 PM   #3
honeywell thermstat
I forgot to say I can't find the same one, I need to know what will work for a replacement.
Old 01-04-2008, 12:58 PM   #4
USP45's Avatar
Rewards Points: 150
sorry, waite for another response for that. If you dont get a response then you may can contact a HVAC dealer who sells parts. Ask which one will work and if it has a wiring diagram with it. If I were there doing it I could, but to explain it is too hard as there is many variables and I would more than likely need to see the 2 thermos and the unit to be sure of proper connections.
Old 01-04-2008, 05:53 PM   #5
Union HVAC Tech.
Look on the old control and see what the model number is, they have to have a compatible control. Post the number and I can match it up to something.
bigMikeB is offline   Reply With Quote
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 04:49 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
