-   -   honeywell wall thermstat (http://www.diychatroom.com/f17/honeywell-wall-thermstat-15153/)
fisherman 01-04-2008 11:51 AM
I have ceiling heat with honeywell wall controls. need to replace but don't know how? any ideas. thanks p.s. just the thermal controler, not the whole heating system
USP45 01-04-2008 12:02 PM
If your replacing just the thermostat I would purchase the same kind, then as each wire comes off, simply install it on the new one right away. Dont try to remove all of them then re install as you may forget where they went. Transfering them one at a time is the safest way IMO.
fisherman 01-04-2008 12:33 PM
honeywell thermstat
I forgot to say I can't find the same one, I need to know what will work for a replacement.
USP45 01-04-2008 12:58 PM
sorry, waite for another response for that. If you dont get a response then you may can contact a HVAC dealer who sells parts. Ask which one will work and if it has a wiring diagram with it. If I were there doing it I could, but to explain it is too hard as there is many variables and I would more than likely need to see the 2 thermos and the unit to be sure of proper connections.
bigMikeB 01-04-2008 05:53 PM
Look on the old control and see what the model number is, they have to have a compatible control. Post the number and I can match it up to something.
