Honeywell VisionPro Thermostat - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 12-16-2008, 02:34 PM   #31
An old Tradesmen
Rewards Points: 6,928
I have never left an electric aux heat set to 9.
It can actually cause you to have a higher heating bill.
If you use 9 for your aux CPH. You end up having the HP go into continuous run when its only 2 or 3 degrees below the HPs thermal balance point.
You end up using more electric that way at mild outdoor temps.
Old 12-16-2008, 06:24 PM   #32
Rewards Points: 129
But I thought that nine would bring the aux. on more often, and 3 would bring it on less often.
Wouldn't it coming on more often bring the desired temp up faster than less often?
One of my main complaints is that my unit runs almost continuously when the od temps are like 37 and below. Based on what you're saying, my run time would be reduced if I change it to 3, right?
jeepgrady is online now   Reply With Quote
Old 12-17-2008, 03:44 AM   #33
An old Tradesmen
Yes, setting it to 3 will reduce your run times.
Set it to 2, and it will reduce it a bit more.
Setting it to 9, means your heat pump will run 24/7 as long as the outdoor temps are below thermal balance point. Since the aux can't cycle 9 times if it satisfies the heat call, and the HP is set to 3 CPH.
Honeywell Thermostat Wiring Differences DavidHwang HVAC 16 01-28-2012 02:11 PM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 04:43 AM
Wiring/Programming of a Honeywell TH8320 Thermostat homrjheath HVAC 4 10-15-2008 01:30 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 07:40 AM
