Honeywell VisionPro Thermostat - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-15-2008, 08:14 PM   #16
I was not going to use set back because of the reason you stated about not saving on energy. If you feel I should I can purchase the outdoor sensor & wire that in in the future.
infoskr is offline   Reply With Quote
Old 12-15-2008, 08:21 PM   #17
probably a good idea to purchase outdoor sensor & wire it in. It seem like it may be the best setup? How do you feel about this.
Old 12-15-2008, 08:29 PM   #18
In the instruction manual is shows there is a system test at the end of the setup functions ( Installer System Test). If you go into that menu it shows testing the cooling system is the first item on the test. Can you bypass the cooling test or is it just better to avoid it all together at this point. Do not want to test the AC in the weather we have here & damage my equipment. The instructions show this as the 1st test.
Old 12-15-2008, 09:09 PM   #19
Honeywell VisionPro thermostat
Thank you for your help beenthere. Appreciate the time spent.
Old 12-15-2008, 09:19 PM   #20
An old Tradesmen
Rewards Points: 8,202
On a heat pump, it won;t hurt it to run in cooling mode for a few minutes.
Every time it goes into defrost, its in cooling mode.
The outdoor sensor pays for its self, if you do use set back.
Old 12-15-2008, 09:25 PM   #21
I have no problem with installing the outdoor sensor see your point.
I am going to follow all your instructions to the letter, and again thank you very much for your time.
Old 12-15-2008, 09:36 PM   #22
Hi, beenthere. Been following some of your posts to others here. Has been interesting. Some things to learn from it all. Also see that some people are a bit insane. You must have some unusual times in from of the ole PC.
Old 12-15-2008, 09:40 PM   #23
An old Tradesmen
Yep.
I do.
Old 12-15-2008, 09:52 PM   #24
So I guess you have lots of good stories at gatherings.
Old 12-15-2008, 09:55 PM   #25
Rewards Points: 150
Originally Posted by infoskr View Post
.....beenthere...... You must have some unusual times in front of the ole PC.
You have no idea!!
Beenthere is "the man" across multiple sites and have provided invaluble assistance to many...including yours truly (me)....
Not just homeowners but many many professionals seek his councel
Key1
In the land of the blind....the man with one eye is king....
key1cc is offline   Reply With Quote
Old 12-15-2008, 10:02 PM   #26
I feel very thankful and now honored by his help
Old 12-15-2008, 10:06 PM   #27
After reading some of the Dangerous and insane things some people are doing you just hope that one of them is not your neighbor, who may blow up, burn their home to the ground or worse.
Old 12-16-2008, 04:20 AM   #28
An old Tradesmen
Thanks Key.
There are a lot of repairs and installs. That just make you cringe when you come upon them.
And you do run into some humorous things also.
I have been attacked by dogs.
Stuck in the snow after midnight.
Swung at by a guy that thought I was going to mug him(real bad section of a city).
Received some real good tips.
Been offered sex as payment.
Called a theif.
Called a saint.
Not been paid.
Gone to the wrong house, and serviced a furnace.
Stuck on a roof, in Febuary, when it was 0F outside(you don't forget to tie off your ladder ever again after that).
Taken a couple trips to the emergency room.
Wrecked a van going to a call, on an icy road, and found out later the guy hadn't had a working furnace for 3 years. But his mother inlaw was coming for dinner that Sunday. And he didn't want her to know they only used a kerosene heater.
And that was just last month.
Old 12-16-2008, 06:57 AM   #29
Rewards Points: 150
ROFL
And why was it again I should become a HVACer
Oh yeah...The sex for payment part.....
Key1
Old 12-16-2008, 11:43 AM   #30
Rewards Points: 129
Originally Posted by beenthere View Post
Yea, 9 is way out of line.
I generally set cycle rates to 3 for compressor, aux heat, and emergency heat.
Some times, I'll set the aux to 2, if I want the aux heat to satisfy the heat call and not run the compressor 24/7 when the outdoor temp is below balance point.
Do you have 0170, set to 7.
Wouldn't changing the Aux. cycle from the recommended 9 to 2 or 3 make the aux come on less frequently than nine?
jeepgrady is online now   Reply With Quote
Honeywell Thermostat Wiring Differences DavidHwang HVAC 16 01-28-2012 02:11 PM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 04:43 AM
Wiring/Programming of a Honeywell TH8320 Thermostat homrjheath HVAC 4 10-15-2008 01:30 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 07:40 AM
