Honeywell VisionPro IAQ YTH9421C1002 Wiring Help - HVAC - DIY Chatroom Home Improvement Forum
Old 11-22-2010, 09:22 PM   #1
Lightbulb
I need help wiring a Honeywell VisionPro IAQ Programmable MultiStage Thermostat with Total Home Comfort Control YTH9421C1002
I have a heat pump and furnace, in total there are 3 stages of heat
One Heat Pump
Two Gas Furnace - Low Fire
Three Gas Furnace - High Fire
One stage for cool
Can you help me set these up on the Equipment Interface Module..
Here is My system :
Goodman SSZI60361 Heat Pump
Goodman GMV950704CX 95% 2-stage, Variable Speed furnace
Goodman CAPF4961C6
Goodman TX3N-4 Expansion Valve
Honeywell C7089U1006 Outdoor Temperature Sensor‏
jond777 is offline   Reply With Quote
Wiring a Honeywell RA89A Relay shawnmd HVAC 9 10-17-2016 06:52 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Wiring a Honeywell ProVision TH8321U1006, upgrade from Weathertron Tstat drandersoninc HVAC 6 10-04-2009 03:20 PM
Honeywell VisionPro Thermostat infoskr HVAC 32 12-17-2008 03:44 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
