Honeywell Visionpro IAQ Function 406 Ventilation In High Humidity ? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-07-2010, 07:04 PM   #1
Honeywell Visionpro IAQ function 406 ventilation in high humidity ?
Hi
I installed the Honeywell Vision Pro IAQ myself and everything works fine except for this small glitch that i can't seem to figure out.
Firstly i have this equipment.
New High efficiency GFA furnace and AC
New HRV ventilator
New Whole house Dehumidifier
New Whole house Humidifier
I do NOT want the vent function 406 ie my HRV to come on when i have high humidity - that's what i have a Dehumidifier for.
So i set function
406 = Ventilation in high humidity = 0 =OFF
Honeywell explains it like this
{When set to On = 1 will use ventilation to remove humidity
when thermostat is in the heat mode - this allows the ventilation equipment to turn on if the
humidity rises approximately 10% above the RH setting in
heating mode to exhaust the extra humidity}
Then to test it i manually I set the humidity set point more than 10% LESS than the current humidity on the thermostat.
example
if current humidity reading on thermostat = 40%
i manually set the humidity setpoint to 25%
Then the Ventilation will come on but i told it in 406 to = 0 =off??????
Even i turn the humidity control on the thermostat from auto to OFF it will still keep the ventilation because it see the humidity greater than 10% above my humidity setpoint?
If i manually turn the humidity setpoint back to within 10% of the humidity reading then the ventilation turns off.
what am i doing wrong here because everything else works beautifully?
Thanks again
Charlie123 is offline   Reply With Quote
Old 05-08-2010, 12:19 PM   #2
An old Tradesmen
Rewards Points: 6,590
If its last call was a heating call. It thinks its still to do heating operations. Run it through a A/C call. Se if it works right then.
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 08:42 PM
High humidity in house in winter reddog General DIY Discussions 7 06-28-2011 06:38 PM
High humidity for how long????? timchi29 Remodeling 2 11-14-2008 07:43 PM
high humidity in basement orange HVAC 17 08-20-2008 02:24 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 03:41 PM
