Honeywell VisionPro 8000 Temperature Variation - HVAC - DIY Chatroom Home Improvement Forum
Old 12-31-2007, 08:36 PM   #1
Hello,
I'm a newer home owner (and therefore new DIYer). Recently, I upgraded my thermostat to the Honeywell (model TH8110U1003). Installation went fine, and it runs great - however - it registers the temperature 3-6 degrees cooler than every other thermometer in the house. I even placed a digital one on the top of the thermostat with the same results.
Apparently, the Honeywell uses some fuzzy logic to determine the temp - utilizing some formula of radiant and ambient heat with two sensors. The drywall is much cooler than the air, but there isn't any air transfer (no holes from the wiring, etc.).
Obviously, this can be dealt with by simply adjusting the heating triggers downward. But, it's odd to program everything -5 degrees less than actual air temp?
Any suggestions? I didn't see any calibration options in the manual. I thought about inserting a little foam pad between the wall and thermo, but that probably won't help much.
Thanks,
-hottoddy
hottoddy is offline   Reply With Quote
Old 01-01-2008, 01:08 AM   #2
Union HVAC Tech.
Do you have the programming booklet that comes with the t stat? If you go into programming there is a spot to set the display temp but, you need the pamplet to get the right code number to adjust.
bigMikeB is offline   Reply With Quote
Old 01-01-2008, 09:06 AM   #3
biggles's Avatar
pop the stat off and put your face up to the hole the wires come out might be catching a draft from the wall into the back of the stat?
Old 01-01-2008, 01:33 PM   #4
Thanks! That helps although the maximum offset is 3 degrees. This code was not one of those in the main booklet, but I did locate it in the extra installation materials. I believe this therm supports external sensors for other parts of the house and outside. I may look into that option as well.
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 04:43 AM
Carrier Infinity Control VS Honeywell VisionPRO 8000 Theromostat super_man4471 HVAC 2 04-26-2007 02:27 PM
