Honeywell Vision Pro, Fan Always On? And True Steam Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 06-19-2012, 06:00 PM   #1
Honeywell vision pro, fan always on? and True Steam problem
Hi
I have a Vision Pro 8000: TH8320U1008
True Steam HM509W1005
Variable speed furnace
Heat Pump Armstrong
Question#1: The Fan is always on: the Green Wire from the thermostat is always with 24 Volts. Even with the Fan off in the thermostat.
Question#2: How to wire the True Steam from Honeywell?
I used Page 15 from this link:
http://customer.honeywell.com/techli...69-2036EFS.pdf
Dip 4-5 on
The problem: if I disconnect the GF Wire at the True steam (Fan input from the termostat) the True Steam continue to steam. Why??
For reference here is my wire:
Thermostat G: Green wire to True Steam GT (Fan Input from Thermostat)
Thermostat Y2: Black wire to Heat pump black wire and to Furnace blue wire
Thermostat Aux: White wire to Heat pump white wire and to furnace white wire
Thermostat RC jump with R: Red wire to Humidifier RT and to Heat pump and Furnace red wire
Thermostat O/B: Orange wire to Orange heat pump and furnace orange wire
Thermostat Y: Yellow wire to Heat pump and furnace yellow wire
Thermostat C: Blue wire to Humidifier C, heat pump and furnace Blue wire
At the True Steam:
24v: nothing
24v: nothing
Hum: Mecanical humidistat
C: Blue wire from Thermostate, heat pump and Furnace
GT: Green Wire from Thermostat Fan output
R and RT jumper + Red wire from Thermostate, Heat pump and furnace
GF:wire go to Green wire from the furnace (fan)
Any help is welcome
Thank you
c5sb is offline   Reply With Quote
Old 06-19-2012, 06:04 PM   #2
JJboy's Avatar
Originally Posted by c5sb View Post
Hi
Heat Pump Armstrong
Dip 4-5 on
At the True Steam:
24v: nothing
24v: nothing
Any help is welcome
Thank you
Disconnect the G wire from the thermostat....The Blower Motor should stop work.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 06-19-2012, 07:42 PM   #3
If I do that I lost the fan control.
Old 06-19-2012, 07:44 PM   #4
JJboy's Avatar
I know, I'm trying to isolate the thermostat
Old 06-19-2012, 08:20 PM   #5
I disconnect the wire at the termostat and the Fan stop. If i ask for cold, the fan start. The thermostat is broken?
Any setting to look for ?
Thank you
Old 06-19-2012, 08:49 PM   #6
JJboy's Avatar
First you need to find the 24V wire, Call for cooling wire ....you already know G (Fan).
If you connect these 3 wires you should have cold and fan on.
Old 06-19-2012, 09:08 PM   #7
An old Tradesmen
Rewards Points: 7,274
Check your program settings. if the program settings have the fan set to on. It will run the fan no matter what you set it to on the main display.
Honeywell TrueSteam Humidifier Opinions/Experience dgbehrends HVAC 239 01-16-2012 03:08 PM
Honeywell TrueSteam wont work! Stewart Daniel General DIY Discussions 18 12-20-2010 07:41 AM
Is Honeywell True Steam a correct choice? Irena HVAC 5 12-16-2010 09:47 PM
Honeywell Truesteam FalconX HVAC 3 01-03-2010 07:47 PM
True Steam Humidifier installation? kcrossley2 HVAC 1 01-01-2009 09:14 AM
