-   -   Honeywell vision pro, fan always on? and True Steam problem (http://www.diychatroom.com/f17/honeywell-vision-pro-fan-always-true-steam-problem-147617/)
c5sb 06-19-2012 06:00 PM
Hi
I have a Vision Pro 8000: TH8320U1008
True Steam HM509W1005
Variable speed furnace
Heat Pump Armstrong
Question#1: The Fan is always on: the Green Wire from the thermostat is always with 24 Volts. Even with the Fan off in the thermostat.
Question#2: How to wire the True Steam from Honeywell?
I used Page 15 from this link:
http://customer.honeywell.com/techli...69-2036EFS.pdf
Dip 4-5 on
The problem: if I disconnect the GF Wire at the True steam (Fan input from the termostat) the True Steam continue to steam. Why??
For reference here is my wire:
Thermostat G: Green wire to True Steam GT (Fan Input from Thermostat)
Thermostat Y2: Black wire to Heat pump black wire and to Furnace blue wire
Thermostat Aux: White wire to Heat pump white wire and to furnace white wire
Thermostat RC jump with R: Red wire to Humidifier RT and to Heat pump and Furnace red wire
Thermostat O/B: Orange wire to Orange heat pump and furnace orange wire
Thermostat Y: Yellow wire to Heat pump and furnace yellow wire
Thermostat C: Blue wire to Humidifier C, heat pump and furnace Blue wire
At the True Steam:
24v: nothing
24v: nothing
Hum: Mecanical humidistat
C: Blue wire from Thermostate, heat pump and Furnace
GT: Green Wire from Thermostat Fan output
R and RT jumper + Red wire from Thermostate, Heat pump and furnace
GF:wire go to Green wire from the furnace (fan)
Any help is welcome
Thank you
JJboy 06-19-2012 06:04 PM
Originally Posted by c5sb (Post 947209)
Hi
Heat Pump Armstrong
Dip 4-5 on
At the True Steam:
24v: nothing
24v: nothing
Any help is welcome
Thank you
Disconnect the G wire from the thermostat....The Blower Motor should stop work.
c5sb 06-19-2012 07:42 PM
If I do that I lost the fan control.
JJboy 06-19-2012 07:44 PM
I know, I'm trying to isolate the thermostat:thumbsup:
c5sb 06-19-2012 08:20 PM
I disconnect the wire at the termostat and the Fan stop. If i ask for cold, the fan start. The thermostat is broken?
Any setting to look for ?
Thank you
JJboy 06-19-2012 08:49 PM
First you need to find the 24V wire, Call for cooling wire ....you already know G (Fan).
If you connect these 3 wires you should have cold and fan on.
beenthere 06-19-2012 09:08 PM
Check your program settings. if the program settings have the fan set to on. It will run the fan no matter what you set it to on the main display.
