Old 02-01-2009, 12:43 PM   #1
Default Honeywell Vision Pro 8000 TH8320U1008 Thermostat Question
I recently purchased a Goodman 115,000 BTU 95% Efficiency, Two Stage Burner, Variable Speed Blower, Upflow/Horizontal Application Gas Furnace and installed a Honeywell Vision Pro 8000 TH8320U1008 thermostat.
I think it can be argued that I oversized the furnace, but I have about a 2500 square foot house with high exposed ceilings, lots of skylights, and a whole wall of windows...some of which are single pane.
That aside, my first issue is that I don't really like the Adaptive Intelligence Recovery or whatever it is that turns the heater on prior to when you set it so that it reaches the temperature at the set time, but I think I can turn that off right?
The other setting that I'm hoping someone on this forum can tell me about is how to adjust the thermostat so that it doesn't so strictly try to maintain the temperature.
For example this morning in my house it was probably low 60s...maybe 61. I have the thermostat set for 67 at 8am and to hold that temp all day. The furnace came on well before 8am on high and blasted for a while and brought it up to temp...took maybe 20 minutes or something. Then every 15 minutes or so since it's come on at the low level to maintain the temperature I guess. I could swear that when it did this yesterday (just installed it yesterday) the inside temp was 67 and it was still turning on.
So I guess my question is, is there a setting that will allow me to specify the number of degrees of buffer between the inside temp and when the heater comes on? Meaning, if I have the thermostat set for 67, I don't want it to come on every time it dips slightly below 67, I wouldn't mind it dropping to 65 or so.
Any ideas?
Thanks guys!
chetwynd is offline   Reply With Quote
Old 02-01-2009, 01:47 PM   #2
An old Tradesmen
No.
he 8320 doesn't have a droop adjustment.
You can how ever, adjust the CPH, if its at 3, set it to 2 and see how you like it.
And yes, you can turn off the adaptive recovery.
Since it was just installed yesterday. You should wait a few ore days before changing thing.
It does take a few days for it to learn the house.
Old 02-01-2009, 10:43 PM   #3
Default no swing...
I recently replaced my Honeywell thermostat for the same thing. Honeywell thermostats will try to maintain the temp to within 1 degree and it is not adjustable. My furnace was turning on all the time. I replaced it with a thermostat with an adjustable "swing" setting. Much better now.
bmik2729 is offline   Reply With Quote
More On This Topic
The thermostat on your wall that controls your HVAC system is the key to your comfort. Knowing how it interfaces with your heating and air conditioning system can help you stay comfortable during long, cold winters and hot, sweltering summers. A key part... Read More »
Depending on where you live in the United States, you may encounter high monthly bills for heating your home. Many homes in warmer climates are built with wide windows and open floor plans, so unexpected low temperatures often result in cold, drafty... Read More »
Next, let me show you what you need to do. Take this ingot, which is a blended lead alloy, lower this into the furnace, which already has molten lead in there, and let it mix within the lead. Be mindful of the temperature that you have this on. You don... Read More »
On behalf of expertvillage.com, my name is Dean Forrest with Sedona Coffee Roasters. I am here to tell you about roasting coffee. The Probat L12, we start every roast by pouring beans into this hopper. L12 means 12 kilos and will hold a little over 25-26... Read More »
Everyone can benefit from using less energy in their homes. You save money each month on your power bill, plus you have the happy knowledge that you are helping the environment by making your home more energy efficient. If everyone did a few energy... Read More »
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 06:43 AM
Honeywell VisionPro Thermostat infoskr HVAC 32 12-17-2008 05:44 AM
Wiring/Programming of a Honeywell TH8320 Thermostat homrjheath HVAC 4 10-15-2008 03:30 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 09:40 AM
Carrier Infinity Control VS Honeywell VisionPRO 8000 Theromostat super_man4471 HVAC 2 04-26-2007 04:27 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
