Honeywell Utica Boiler Valves Question - HVAC - DIY Chatroom Home Improvement Forum
Old 02-02-2009, 08:16 PM   #1
Greetings!...
I have a Utica Boiler (Honeywell) and I think my daughter (3 yrs. old) may have turned the two black valves that are above and below the glass water meter tube. I am not sure in what position the valves should be -- open or closed -- but i now have noticed that the red "low water level" light switches on even though the glass tube is totally full of water.
Any ideas?
Many, many thanks!
cmariorussell is offline   Reply With Quote
Old 02-03-2009, 03:26 PM   #2
JohnH1's Avatar
If this is a steam boiler the valves should both be open. Counter clockwise is open. As far as the water leavel you should be able to see one somewere in the glass it should neather bee all the way full or empty.
JohnH1 is offline   Reply With Quote
Old 02-03-2009, 09:54 PM   #3
THanks!
Boiler w. Hydronic Air & Honeywell Aquastat DanA28 HVAC 1 01-08-2009 04:21 PM
Weil-Mclain boiler question Boiler1 HVAC 1 12-28-2008 11:25 PM
utica boiler ignites for 5 sec. then shuts off UBoiler HVAC 17 07-21-2008 09:40 AM
Question on Refilling / topping off Weil McLain Boiler memovox2 HVAC 4 02-01-2008 10:05 AM
question about cleaning a boiler room Piratehart General DIY Discussions 1 02-14-2006 12:58 PM
