Old 11-30-2008, 06:19 AM   #1
Honeywell TrueSteam Humidifier?
I'm considering adding a Honeywell TrueSteam humidifier to my gas heating system(s). I'd like to humidify a 4,300 sq. ft. house with three floors and three separate heating units. I'm considering a steam unit because the area where I live (Williamsburg, VA) has very expensive water rates and I've read that these type of systems are much more water efficient.
The first and second floors have Goodman natural gas heating units. The finished attic has a Mitsubishi mini-split. The unit that serves the first floor is located in an insulated garage right next to my hot water heater and near an electrical outlet. The unit that serves the second floor is located in an unconditioned space within the attic, which exceeds the operating range of the TrueSteam.
Here are my questions.
1. Will one TrueSteam installed on the garage system cover the entire home?
2. If so, what size TrueSteam unit will I need?
3. How difficult is the system to install?
4. For those of you who have the TrueSteam system, how do you like it?
5. Is there anything else I need to consider?
Thanks for your help!
kcrossley2 is offline   Reply With Quote
Old 11-30-2008, 07:17 AM   #2
An old Tradesmen
Your house, is larger then a single Truesteam can handle.
But, Truesteams can be remote mounted.
So it would be possible to mount one somewhere within 20' fo the second floor unit, and run the hose to the duct of the second floor unit.
Giving you 2 Truesteams.
Have you tried to seal your house bettter. Leaky houses need humidifiers, tight houses don't.
Old 11-30-2008, 09:24 AM   #3
Hvac Pro
I have installed those units and they are very tricky to size and install. They need lots of airflow and have specific locations for the spray nozzle etc. They need a separate 120 volt circuit to the unit. Can use up to 10 amps. I would try find a contractor with experience on them to install it. If not done right the steam can condense in the ductwork and damage will occur. They are good for large furnaces with lots of airflow/large ducts. I would guess that it costs as much for the electricity for the heating element as it would for water with the other types. They are very good for large applications where more humidity is required than a flo thru can produce. Do lots of reading and research B4 installing one of these. Let me know if you want more info. http://customer.honeywell.com/Honeywell/UI/Pages/Catalog/ComponentCategory.aspx?Catalog=Homes&Category=Stea m+Humidifiers_10961&ChannelID={2EB2F178-20ED-44E0-97FB-CCFB4218DD64} Go to the bottom of those pages for install manuals/pdf files etc.
Good Luck
Old 12-01-2008, 04:22 PM   #4
Jay
This may be helpful:
http://www.hotfreshcool.com/truesteam_video.html
jaymes is offline   Reply With Quote
More On This Topic
When it comes to decorating for the holidays, the biggest chore is figuring out how to store your decorations after the holiday is over. If you're stuck wondering how to store Valentine's Day decorations, fret no more. Here are some simple ways to keep... Read More »
The thermostat on your wall that controls your HVAC system is the key to your comfort. Knowing how it interfaces with your heating and air conditioning system can help you stay comfortable during long, cold winters and hot, sweltering summers. A key part... Read More »
When a family is looking to add a humidifier, it's usually for a child's room. Humidifiers will help children with stuffy noses, especially in dry winter air. Also of note, a humidifier can also help dispel snoring that is caused by that same dry air... Read More »
The garage is one of the largest spaces in the home and it is usually the most congested and cluttered. A simple solution for garage clutter is to use well designed storage systems. Here is how to design a garage for maximum usability and storage. Read More »
If you are at a loss as to what to do with your keepsakes, handed down furniture, year books, children’s toys or holiday ornaments, you should look up and consider your attic. Homes used to be made with stairs that went to the attic. Here children... Read More »
Honeywell TrueSteam Humidifier Opinions/Experience dgbehrends HVAC 163 03-09-2010 06:32 PM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 05:43 AM
Honeywell TrueSteam Direct-Injection Humidifier jaymes HVAC 3 12-01-2008 04:25 PM
Humidifier & Thermostat BigD HVAC 1 12-19-2007 09:04 PM
Honeywell Humidifier dcd22 HVAC 5 11-01-2007 09:36 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
