Honeywell TrueSteam Direct-Injection Humidifier - HVAC - DIY Chatroom Home Improvement Forum
Old 11-29-2008, 09:58 AM   #1
Jay
I just purchased a Honeywell TrueSteam Direct-Injection Humidifier (model HM512DG115 with True IAQ Digital Control). Any advice (wiring, plumbing, etc) before I attempt to install?
jaymes is offline   Reply With Quote
Old 11-29-2008, 10:07 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,826
Are you a skilled HVAC mechanic. I have installed those units and Honeywell has VERY specific guidelines where the spray nozzle needs to be etc. The wiring on those IAQ systems if it has the interface module is VERY tricky. If the steam spray does not have access to lots of airflow or it hits the duct or A coil it will condense and you will get water damage inside your furnace etc. Do lots of reading and research B4 installing that unit. I usually recommend a General Air 1042 flow thru unit unless you have a need for LOTS of humidification. Let me know if you need more info. Check this link:http://www.generalaire.com/catalog/categories/584
More info at this site:http://customer.honeywell.com/Honeywell/UI/Pages/Catalog/ComponentCategory.aspx?Catalog=Homes&Category=Stea m+Humidifiers_10961&ChannelID={2EB2F178-20ED-44E0-97FB-CCFB4218DD64} Got to the bottom of those pages for install pdf files etc.
Old 11-29-2008, 11:28 AM   #3
Jay
Hi Yuri: Thanks for the info.
I'm not a skilled HVAC mechanic. I'm just a retiree with not enough money and too much time on my hands. I downloaded the "Professional Installation Guide" (69-2035EFS-01.pdf, 24 pgs) and the Operating Manual (69-2036EFS-01.pdf, 20 pgs) from the Honeywell web site. The first page of the install guide says: "As Easy as 1-2-3-4." Ha! I'll see.
Old 12-01-2008, 03:25 PM   #4
Jay
Yuri: There's an installation overview video also: http://www.hotfreshcool.com/truesteam_video.html
Honeywell TrueSteam Humidifier Opinions/Experience dgbehrends HVAC 239 01-16-2012 03:08 PM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 04:43 AM
Humidifier & Thermostat BigD HVAC 1 12-19-2007 08:04 PM
Honeywell Humidifier dcd22 HVAC 5 11-01-2007 08:36 AM
