Is Honeywell True Steam A Correct Choice? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-16-2010, 01:27 PM   #1
Is Honeywell True Steam a correct choice?
First of all, let me apologies for my invasion into the menís field. Weíve bought a project, yes, it is not a house, but a project. 25 years old raised bungalow which we rebuilding and extending. My husband is a construction technician and a millwright, so he does all the jobs. He hates computers and will not sit two minutes to do what Iím doing now.
Here is a question. Our house is around 1400 sq feet on the main floor, and same amount for the basement. We will be adding another 400 or so sq feet to the main floor. At present moment, it is VERY loose. We are working on it. Eventually, it will be tight. There is a chance we will be adding a loft as well (prob. another 500 -600 sq. feet).
Right now, Iím looking into installing HRV and humidifier. I know I donít need HRV in the loose house, but I donít want to start all the mess in the basement again once it will be properly done. The HRV will be two-stage Vanee HRV 90HVECM. My question is Ė what will be best Humidifier in this scenario? I have my eye on Honeywell True Steam 9 gal. Will it be right choice? How to strike the balance between HRV and humidifier? Then there is a window frost questionÖ We are in Ontario, and -10- -20C is our normal winter temp. In the house, we keep it at 20C. We need humidifier only during winter.
Thanks for your help.
Irena is offline   Reply With Quote
Old 12-16-2010, 05:34 PM   #2
What's your water like? We have very hard water and the true steams are just a pain in the behind to keep operating. You couldn't pay me enough to put on in our house.
Get a good bypass humidifier for now. Once the house is tightened up you might not even need one.
The Following User Says Thank You to Marty S. For This Useful Post:
Irena (12-16-2010)
Old 12-16-2010, 05:58 PM   #3
An old Tradesmen
Rewards Points: 8,168
Aprilaire 600A bypass flow thru humidifier connected to the hot water line will be more reliable. And be able to add more moisture to the air then that TS9.
And cost lots less to buy and use.
The Following User Says Thank You to beenthere For This Useful Post:
Irena (12-16-2010)
Old 12-16-2010, 06:08 PM   #4
Thanks a lot. Will it work with a tankless water heater?
Old 12-16-2010, 06:13 PM   #5
Our water is very hard, but we use water softener.
Old 12-16-2010, 09:47 PM   #6
An old Tradesmen
Using the hot water won't work. It doesn't use enough water to bring the heater on.
It will still work to humidify your house though.
Honeywell TrueSteam Humidifier Opinions/Experience dgbehrends HVAC 239 01-16-2012 03:08 PM
Honeywell TrueSteam wont work! Stewart Daniel General DIY Discussions 18 12-20-2010 07:41 AM
Honeywell Truesteam FalconX HVAC 3 01-03-2010 07:47 PM
Converting steam heat to hot water??? pcampbell HVAC 31 02-17-2009 08:26 PM
True Steam Humidifier installation? kcrossley2 HVAC 1 01-01-2009 09:14 AM
