Honeywell Thermostat Runs Continuously - HVAC - DIY Chatroom Home Improvement Forum
Old 02-26-2015, 09:34 AM   #1
Honeywell Thermostat runs continuously
Installed a pretty basic Honeywell thermostat and once it reaches the set temperature the fan will not cut off on it's own. Its on auto. Turns off it you reduce the set temp by five or so degrees or if you reduce it by one and turn the switch to off, then
Back on to heat, My friend has the same thermostat with the same issue. Seems like a waste of energy. Could this be fixed?
ga1809 is offline   Reply With Quote
Old 02-26-2015, 12:07 PM   #2
Rewards Points: 907
What is the model number on the honeywell. What kind of system do you have?
Bitters is offline   Reply With Quote
Old 02-26-2015, 01:06 PM   #3
RTH3100C, heat pump systems, mine is a Westinghouse 3 ton, and his is a smaller Goodman, both have a jumper wire from W to Emergency heat and his has a blue wire to C, mine has a brown wire to C
Old 02-26-2015, 01:53 PM   #4
Rewards Points: 907
Does the heat pump go off but the indoor fan continue to run?
Old 02-26-2015, 02:05 PM   #5
Correct. Heat pump off, fan stays on, air feels cool, aux heat occasionally cuts on
Old 02-26-2015, 03:51 PM   #6
Rewards Points: 907
Lets make sure it's not a problem in the furnace. Turn off power to the furnace. Remove the stat to expose the wire's and take R and G off the stat and twist them together. Turn the power back on. Fan should run, then separate the wire's and see if the fan stop's. Do you have electric strip's for back up heat or is it gas?
Old 02-26-2015, 04:23 PM   #7
Passed that test, ran twisted together, cut off when pulled apart. Electric heat strips.
Old 02-26-2015, 04:32 PM   #8
Rewards Points: 907
OK, it's in the stat. On the stat make sure function 6 is set on 9 and function 8 is set on 9.
Old 02-26-2015, 04:58 PM   #9
An old Tradesmen
Rewards Points: 8,154
Are you sure the heat pump isn't in defrost when you notice this.
Old 02-26-2015, 06:21 PM   #10
I'll check when I get home. Out of curiosity if the white wire was unhooked from w, would the aux option be no longer an option? Like if i wanted to run only heat pump heat ? Or could i run the white wire just to Emergency heAt, no jumper to aux?
Old 02-26-2015, 06:55 PM   #11
Rewards Points: 3,256
Yes and Yes. The aux heat will still come on during defrost however.
zappa is offline   Reply With Quote
Honeywell thermostat and heat pump fls HVAC 4 11-02-2014 01:05 PM
Wiring honeywell thermostat cincinnati guy HVAC 28 10-29-2014 06:09 PM
The Right Thermostat? (Honeywell says two diffrerent things) FourIsWaltz HVAC 3 10-10-2010 08:20 PM
Replacing Honeywell thermostat with another Honeywell flipz HVAC 4 02-06-2010 04:19 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 07:40 AM
