Honeywell Thermostat RTH2410B1001 - HVAC - DIY Chatroom Home Improvement Forum
Old 05-02-2013, 02:05 AM   #1
Rewards Points: 12
Honeywell thermostat RTH2410B1001
I have a Honeywell thermostat RTH2410B1001 that I am trying to install. I don't have a O or B wire coming to my thermostat and hence I believe I have no heat pump. There is a jumper JP2 in the thermostat which according to the manual should be set in either O or B position depending upon if I have connected the O or B wire to the O/B wire. Since I have no heat pump should I remove it completely or leave it in the factory default position?
salilsurendran is offline   Reply With Quote
Old 05-02-2013, 04:36 AM   #2
An old Tradesmen
Rewards Points: 8,168
No wire connected to it, makes no difference how its set then.
Honeywell / Honeywell thermostat replacement question. FatBear HVAC 15 05-05-2014 01:15 AM
Replacing old Honeywell thermostat with new Honeywell thermostat optimizer HVAC 13 04-20-2011 06:22 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Replacing Honeywell thermostat with another Honeywell flipz HVAC 4 02-06-2010 04:19 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 07:40 AM
