-   -   Honeywell thermostat RTH2410B1001 (http://www.diychatroom.com/f17/honeywell-thermostat-rth2410b1001-178567/)
salilsurendran 05-02-2013 02:05 AM
I have a Honeywell thermostat RTH2410B1001 that I am trying to install. I don't have a O or B wire coming to my thermostat and hence I believe I have no heat pump. There is a jumper JP2 in the thermostat which according to the manual should be set in either O or B position depending upon if I have connected the O or B wire to the O/B wire. Since I have no heat pump should I remove it completely or leave it in the factory default position?
beenthere 05-02-2013 04:36 AM
No wire connected to it, makes no difference how its set then.
