Honeywell Thermostat Rth 8500 - HVAC - DIY Chatroom Home Improvement Forum
Old 12-27-2011, 08:46 AM   #1
honeywell thermostat rth 8500
hello from a new member !!!
I recently purchased a new honeywell rth8500 thermostat for my heating system, (lennox heat pump with a york elec york furnace), the old thermostat was a honeywell t 8501d
old thermostat wiring diagram
red wire to r for 24 volts ac
orange wire to o/b for reversing valve
yellow to y for compressor
green to g for blower
black to c for common 24 volts
white to w2 for second stage heating and emergency
dark blue to l for service light
also a jumper for y to w1 ???????????????????????
W1 is for first stage (heat) not sure
On the new thermostat i have two rows i will star from left one
first row on top second row on top
Y2 RC jumper between RC & R
L R
E W O/B
AUX W2 Y
g
c
I need help, just want to do a good job because i am not sure.
The installation guide said if your old thermostat had y1,w1 and w2 please contact a contractor.
Thank you very much for your help !!!!!!!!!!!!!!!!!!!!!!!
crunchcrunch33 is offline   Reply With Quote
Old 12-27-2011, 08:51 AM   #2
I did something wrong
new thermostat
row 1 from top y2, L, E, AUX/W2
row 2 from top RC, R, W / O/b, Y, G, C, also a jumper between RC and R
thk
Old 12-27-2011, 10:10 AM   #3
Rewards Points: 6,652
Suggest sitting down and reading the books that came with it. Always works, along with asking before you tackled it.
The Following User Says Thank You to gregzoll For This Useful Post:
bob22 (12-27-2011)
Old 12-27-2011, 06:16 PM   #4
Houston204's Avatar
Rewards Points: 556
Rc & R = red
O/B = orange
Y = yellow
G = green
C = black
Aux and E = white (use a jumper wire)
L = dark blue
option 170 = 7 heatpump with aux heat strip.
The w to y jumper is no longer required.
Houston204 is offline   Reply With Quote
Old 12-28-2011, 09:40 AM   #5
thank,s very much houston 204, works perfectly !!!!!!!!!!!!!!!!!!!!!!!!1
Replacing old Honeywell thermostat with new Honeywell thermostat optimizer HVAC 13 04-20-2011 06:22 PM
Fan setting reads AUTO and ON at same time on Honeywell 8500 thermostat Studly HVAC 1 03-21-2011 08:27 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Replacing Honeywell thermostat with another Honeywell flipz HVAC 4 02-06-2010 04:19 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 07:40 AM
