Honeywell Thermostat Replacement - HVAC - DIY Chatroom Home Improvement Forum
Old 07-31-2010, 04:19 PM   #1
Honeywell Thermostat replacement
Hello sir, I need to replace Honeywell T841A1712 thermostat for AC and Heat pump please tell me with what kind and also with wiring connection.
my Email is khanma2@verizon.net
Thank very much
khanma1 is offline   Reply With Quote
Old 08-01-2010, 07:39 AM   #2
An old Tradesmen
Rewards Points: 6,112
You might want to list what brand and model heat pump you have.
No one can tell you for sure how to wire it, without knowing what it is being wired to. And it helps to know how the old unit is wired.
No need to have someone email wiring instructions to you. They can be posted here. So others can read the instructions later.
Old 08-01-2010, 01:35 PM   #3
Thank very much
Stick with Honeywell. Get a Prestige model or if that's outside of your budget then consider Vision Pro.
Go to Honeywell.com to download the installation and programming manual. You might also find some videos on youtube.
hennyh is offline   Reply With Quote
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
Replacing Honeywell thermostat with another Honeywell flipz HVAC 4 02-06-2010 05:19 PM
Need a programmable thermostat. LUX or Honeywell. speedster1 HVAC 37 12-06-2009 09:33 AM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 05:43 AM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
