Which Honeywell Thermostat To Purchase? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-13-2012, 02:33 PM   #1
Rewards Points: 1,520
Which Honeywell Thermostat to purchase?
My mother is getting a new York TM9V gas-fired furnace with AC. The York is a variable speed, 2-stage unit. I'm thinking the Honeywell VisionPro 8000 (model # th8321ui1006) would be best with this system; correct?
Model info for the York has:
"Two stage heating operation includes two stage gas valve,
two stage inducer operation and variable speed ECM
blower operation.
Adjustable delay timer allows two stage
operation with a single stage thermostat."
Other suggestions/advice is welcomed!
bob22 is offline   Reply With Quote
Old 01-13-2012, 03:16 PM   #2
MarginallyQualified
Rewards Points: 2,464
What did the HVAC pro doing the install recommend be used?
If different... is there some reason you don't like their choice?
Old 01-13-2012, 03:20 PM   #3
Rewards Points: 734
Hi Bob,
I'm not sure about your mother but my parents like simple. They'd rather have something they can touch, and have some feedback, rather than a touchpad and lots of information.
Something like the RTH7500D. Still 7 day programmable and does support 2 stage heat/cool.
They can hit the button to raise the temp easily, turn the fan on/off, or "hold" the temp, no glasses needed.
AandPDan is offline   Reply With Quote
Old 01-13-2012, 03:58 PM   #4
MarginallyQualified
Originally Posted by AandPDan View Post
I'm not sure about your mother but my parents like simple. <--Excellent Point
Something like the RTH7500D. They can hit the button to raise the temp easily, turn the fan on/off, or "hold" the temp, no glasses needed.
and at $40... it's a bargain too!
linky
Old 01-13-2012, 04:11 PM   #5
Guys,
Thanks for the advice. The tech hasn't recommended one yet; I'm just planning ahead and know I can get it for a bunch less then he'll charge her.
Looks like the 7500 is the better option for all the reasons provided.
I appreciate the help!
Bob
Old 01-13-2012, 10:48 PM   #6
Houston204's Avatar
Rewards Points: 556
The Honeywell IAQ would be a better choice with that system.
It looks like the TH8320 but offers better humidity control when used with a variable speed furnace.
Houston204 is offline   Reply With Quote
Old 01-13-2012, 10:53 PM   #7
Missouri Bound's Avatar
I agree with the other posts..get the LARGEST AND SIMPLEST that will work properly.
Old 01-13-2012, 11:06 PM   #8
Houston204's Avatar
Rewards Points: 556
The IAQ is larger and the display is much easier to read. They are both simple to operate. The IAQ is more work to install and will cost more.
Old 01-13-2012, 11:54 PM   #9
An old Tradesmen
Rewards Points: 6,068
And if she also has central A/C, the IAQ thermostat when set up right, will help maintain lower humidity in the summer.
Old 01-14-2012, 08:45 AM   #10
An update: I ordered the RTH7500D yesterday before I got the follow-on suggestions. I can return it if need be.
Since she really won't fiddle with the thermostat once it is set up to match her schedule, how well it works with the furnace and AC system is likely important.
So, should I order the Honeywell VisionPro 8000 (model # th8321u1006) or perhaps a White Rogers 1F85-277 or 1F85-275 or something else?
Old 01-14-2012, 09:13 AM   #11
Hvac Pro
yuri's Avatar
Rewards Points: 1,092
Personally I find the Honeywell Vision Pros which is also part of the IAQ pkg to be hard to read especially in bright sunlight and you have to tap the screen fairly hard or use a stylus to press the icons. Not a huge issue for you but if she wants to change anything it may be frustrating. The White Rodgers of the later 2 are the most user friendly IMO and their True Blue easy readers are a lot more easy to see but just as complicated as the Hwells. Need a fairly experienced tech to properly setup an IAQ system and they are quite rare with those units. You may also find that if the furnace has any problems the installer will blame the tstat or IAQ system and rightfully so if he does not know what he is doing or wants to duck out of the problem. A more basic tsat eliminates any of those problems.
Replacing old Honeywell thermostat with new Honeywell thermostat optimizer HVAC 13 04-20-2011 07:22 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
Replacing Honeywell thermostat with another Honeywell flipz HVAC 4 02-06-2010 05:19 PM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 05:43 AM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
