Honeywell Thermostat Not Shutting Off After Reaching Temp - HVAC - DIY Chatroom Home Improvement Forum
Old 09-06-2011, 03:15 AM   #1
Honeywell Thermostat not shutting off after reaching temp
My Honeywell thermostat is set for 80 during the day and when it reaches 80 it will shut off and then turn back on within a few minutes. I have looked at the installers guidelines and have been hesitant to change much but think there must be a setting that would have a 2-3 degree variation from the set temp. Thanks for the help!
lindanat is offline   Reply With Quote
Old 09-06-2011, 04:34 AM   #2
An old Tradesmen
Rewards Points: 6,824
Honeywell thermostats don't have a temp offset in them. Check the CPH setting, see if its set higher then 3, if so set it to 3 or 2.
Old 09-06-2011, 09:19 PM   #3
Okay ... I have CPh for the following:
1. CPh for 1st stage compressor
2. CPh for 2nd stage compressor
Both of which are set at 3
3. CPh for 1st stage conventional heat
4. CPh for 2nd stage conventional heat
Both of which are set at 5 (stand forced air systems)
5. CPh for 3rd stage heat (auxiliary - do not think I have)
6. CPh for Em heat (emergency heat - ditto 5)
So do you think I should set 1 and 2 to 2? And frankly I don't think I have a second compressor so likely only #1. Thanks loads!
Old 09-06-2011, 09:22 PM   #4
Missouri Bound's Avatar
Has this happened since it was installed? And with extreme weather....very cold or very hot, a "few" minutes isn't too unusual. Some thermostats can be adjusted to have a 2 or 3 degree sweep...yours cannot.
Old 09-06-2011, 10:02 PM   #5
An old Tradesmen
Lower your CPH to 2. An see if that makes it better.
Replacing old Honeywell thermostat with new Honeywell thermostat optimizer HVAC 13 04-20-2011 06:22 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Replacing Honeywell thermostat with another Honeywell flipz HVAC 4 02-06-2010 04:19 PM
Honeywell RTH8500 Programmable Thermostat not reaching scheduled temp- HELP :[ Tramlo HVAC 4 01-18-2009 08:12 AM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 07:40 AM
