-   -   Honeywell Thermostat code 0340-reset? (http://www.diychatroom.com/f17/honeywell-thermostat-code-0340-reset-1412/)
George Foote 12-04-2005 09:19 AM
Hello all.
Can anyone tell me how to reset the code 0340 on a Honeywell Vision Pro8000? The unit was just installed with an outside temperature sensor and the installer forgot to change the default option which is "0" to "2".
George
George Foote 01-06-2006 04:38 PM
Answer
Update ..
The contractor removed the Honeywell thremostat (it was not what I requested in our contract) and has installed the Trane TCONT800 theromstat. They both look almost the same and the solution to the my initial issue is the same ... you must have the "installation instructions" not just the owners manual. The installation instructions covers "ALL" those hinden codes. Be careful here, you really need to know your stuff before you go and change some of those options.
Briefly here's the steps to accessing those codes ...
1. press and release "system" key
2. Next you will see mostly blank buttoms at the bottom
3. Press the two (same time) on either side of the center blank buttom
4. Release, and the middle should have code 0120
Hope this helps.
May16Dix2009 05-16-2009 09:20 AM
I think that is a good help on resetting Honeywell Thermostats...
_________________
Programmable Thermostats
thermostatos 02-14-2011 12:52 PM
i have the honeywell thermostat since 1999 and it works just wonderful, this is a great tool which is neede in every building
http://honeywellthermostat.net/
